Whistle spark plugs
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Whistle spark plugs
Post by WillyR » Thu Jul 24, 2025 3:17 pm
I'm fairly new to model T's and have had lots of fun putting noisemakers on my '24.
I'm trying to learn about the whistle spark plugs.
I see many of the whistle portion of the assembly available. but not the plugs themselves.
teach me about the spark plugs.
I would assume these are specially built plugs, and as usual they are a wear part.
I would like to install one on my car.
but I would prefer not to drill into my head to install just the whistle part.
What is the lifespan of the dedicated plugs? ARE there a plethora of them sitting on the shelf at NAPA?
Can current plugs be modified?
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
Re: Whistle spark plugs
Post by DanTreace » Thu Jul 24, 2025 5:01 pm
Believe you mean an “explosion whistle”.
Those devices for a T have a 1/2” pipe thread base, which has tapped opening to place any 1/2” pipe thread Spark plug. The spark plug does the ignition fire.
The whistle cylinder then carries gases of compression to make the sound, activated by the lever valve via pull chain. The spark plug and whistle component are separate.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Jul 24, 2025 5:08 pm
Yes that's the one.
I see lots of the whistles for sale but not the plugs.
Post by Steve Jelf » Thu Jul 24, 2025 5:14 pm
I can imagine myself using an exhaust whistle, but not this. I want four good spark plugs, intact and well-adjusted. Brand doesn't matter. Champion X, Wards, Splitdorf, Horseshoe, whatever.
Post by DanTreace » Thu Jul 24, 2025 5:17 pm
Any spark plug can be used. Isn’t a need for a custom spark plug. Fit any brand you wish as long as the threads of the plug fit the opening in the whistle.
Post by speedytinc » Thu Jul 24, 2025 5:18 pm
Remove the existing plug. Install the whistle. Put the old plug in the adapter. There is no special plug.
FWIW, I have tried to run these types of whistles in my different T's, all the motors developed a rough running like miss.
So off they went. I have gotten similar feedback from a few other guys.
Post by DanTreace » Thu Jul 24, 2025 5:55 pm
Haven't used an explosion whistle, and for that matter an 1/2" adapter in the cylinder head to install mm plugs.
IMO, it may be helpful to use a 'long reach' plug to get the electrode at least partially in the chamber.
Here is view of chamber with a standard reach plug.
The explosion whistle might be best done with a long reach, like the pretty green Splitdorf early plugs, note this collection shows these plugs with explosion whistles.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Jul 24, 2025 6:05 pm
ahh... it's all making sense.
I had seen plugs specifically for the whistle that don't use the adapter...
like these....(pic stolen from a recent thread here) and that's what "sparked" my interest.
I had not seen the adapter before, but it looks like it is available from at least one of our regular dealers.
I do believe i would try to find some long reach plugs if I were to keep it on the car permanently, or find a few of the dedicated plugs -OR- try to find some long reach with the adapter.
I would imagine I'm reducing compression AND placing the spark in a less than ideal location for regular driving.... so not ideal.
It may be something I install for parades only....
jsaylor
Last Name: Saylor
Post by jsaylor » Thu Jul 24, 2025 6:19 pm
I used one for parades only. I usually had to take the valve apart and clean and re-seat every couple of uses. I finally decided it wasn't worth the trouble and sold it at a swap meet.
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Post by Tadpole » Thu Jul 24, 2025 6:42 pm
Willy, the plugs that were specifically altered for the whistles keep the spark inside the combustion chamber where it belongs, better than the adaptors that were later made. These plugs were mostly (if not all) Splitdorfs altered and sold by Buell to go with their whistles. They are pretty scarce but not impossible to find, I’ve been collecting plugs for three years now and have acquired four. Only one of which fits a T. They were made from the late teens to early twenties. Most of these old plugs will last forever though if treated with care, occasional cleaning, and a spark that isn’t so intense as to cause heavy wear to the electrode.
With a welder, drill and some tubing I imagine one wouldn’t be too hard to make out of a Champion X, if you had the patience.
I like the idea of using a long reach plug with the adapter. I tried that once with a long reach Splitdorf but it wouldn’t fit all the way through the adapter, even when I bored the adapter out some. But there are many long reach plugs out there.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Thu Jul 24, 2025 7:00 pm
Also, if you find usable Splitdorfs, they must be cleaned by hand with gasoline or some other solvent (I’ve found gasoline to work well, and it was frequently recommended for cleaning plugs during the period. Likely because it was on hand anywhere automobiles were and will cut the carbon.). DO NOT use conventional pneumatic spark plug cleaners on mica insulated plugs. The mica sheets are resistant to heat and do not crack or shatter as porcelain does, but the sheeting is thin, brittle and flaky to the touch, especially after excessive wear. These are tough old plugs and resist dropping/cracking (a big selling feature at the time), but the mica is like paper and a wire brush or grit from a pneumatic cleaner will ruin one.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Jul 24, 2025 7:09 pm
I did find a couple older threads here and while some poo poo the idea, I also found where somebunny said they had one installed with no issues for 50 years, and sumbunny else blamed a crankshaft break on one...
I like to fiddle around enough that I think it will be a fun toy.....
it looks like the whistle itself is the easiest part to find, so can be patient.
by the way, I have... so far...
1) the factory horn
2) a bermuda bell
3) an aermore train whistle
4) a wolf whistle
and I put a non-factory pin stripe on my wheels... so irreverent...
the cutout for the aermore, has been a royal pain, but I'm not deterred.... still working on fixing it's perpetual leak...
I'm enjoying my car immensely...
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Thu Jul 24, 2025 7:16 pm
All that stuff will make your car reel Kool, and wheel pinstripes have been proven to increase acceleration.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jul 24, 2025 7:17 pm
And that makes it all worth while :-)
Remember, as you fine tune your car - 'If it works for you - Then it works' ;-)
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jul 24, 2025 7:18 pm
I have an adapter style 'explosion plug'. It is great fun for parades - the faster the engine runs the louder the noise. When you 'pull the chain' you do notice a bit of a drop in engine power while they are chirping.
Considerations:
I found they tend to work loose over (a not very long) time. Nuisance value in regular tightening.
They can make the engine run a little rougher (especially when they are loose) and need more than usual cleaning (plugs carbon up quicker).
I have not really noticed any marked loss of power when running with them in place (when not in use 'sounding').
My solution - put them in for displays/ parades, then whip then out for 'normal running'.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Jul 24, 2025 11:06 pm
I think I’ll hold out for a splitdorf plug or two, depending on the going rate…
The adapter should be under $20 including shipping if the splitdorf is too expensive.
Just bought this on the ebays for $85 shipped…
The seller says the valve actuates, so I should be a leather washer away from functioning….
I’ll place an wanted add here for the splitdorf…
Is that spelled right?
I will also ask for the adapter and long reach plug if anyone has spares of either.
Last Name: House
Post by George House » Fri Jul 25, 2025 6:46 am
I call the explosion whistle in the picture that Dan posted - a crankshaft breaker. Back in ‘76 during the Colorado centennial tour I was a 26 year old kid with an explosion whistle on a T. I loved its ‘chortle’ sound when actuated going down an incline road. When ascending a Rocky Mountain road the actuated singular loud whistle could be heard for miles. This was when my crankshaft broke. My forensic determination was that cylinder explosive power was stolen from the T’s forward momentum and assigned to this damn “hey look at me” device causing engine carnage. I threw the explosion whistle away.
John Codman
Last Name: Codman
Post by John Codman » Fri Jul 25, 2025 3:11 pm
I agree 100%.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri Jul 25, 2025 5:14 pm
I just found one in my stash.
WillyR
First Name: Vilhelm
Post by WillyR » Mon Jul 28, 2025 10:27 am
Yeah, that looks like the adapter..
I'll place an ad here for the buell plug or the long reach plug/adapter....
WillyR
First Name: Vilhelm
Post by WillyR » Mon Jul 28, 2025 10:29 am
I thank you all for your knowledge,
too bad J.C. Whitney isn't around, I'd probably order every damn gadget and gizmo they ever had for a model T....
Post by Norman Kling » Mon Jul 28, 2025 11:29 am
A Model A or other Oooga horn will draw j ust as much attention as a compression whistle, except for the earlier cars without a battery. I had one on one of my cars but didn't like the shaking of the car. I live in the hills where I need every ounce of power the engine will deliver. Also not sure it is good for the crankshaft to jerk like a misfire whenever the whistle is used. The exhaust whistle or wolf whistle is a better option.
WillyR
First Name: Vilhelm
Post by WillyR » Mon Jul 28, 2025 11:48 am
Odd as it may seem, I don't think I want a model A horn on this T, I do also like the push horn on the T roadster cars, but I think I may just get a model A (or 40) and either a roadster pickup or a touring with the push horn.
I have everything to hopefully fix the leaky cutout for the train whistle, but I wasn't motivated to take the car out of circulation this weekend to fix it. (had errands to run)
So far the exhaust whistle sounds great on a long downhill. too high on the rpm's and it's just shrill with no redeeming qualities.....
The wolf of course only sounds good at low idle, due to the engine vacuum.
I'll figure out where the explosion whistle sounds best..
the stock horn and the Bermuda bell sound in any situation....
Post by speedytinc » Mon Jul 28, 2025 11:50 am
"With a welder, drill and some tubing I imagine one wouldn’t be too hard to make out of a Champion X" Credit to Tadpole.
There is the solution.
Spark plugs with the outlet built in are quite rare & big $$. A matching set with one with the outlet built in, like the splitdorfs are mega $$$
Using the adapter pockets the spark making for poor running.
There is no deep reach plug that will extend the plug thru an adapter.
Take apart a new champion & weld in a pipe nipple @ the base & reassemble. Use the same champions for the other 3 cylinders.
Another project to my list.
Post by TXGOAT2 » Mon Jul 28, 2025 12:00 pm
The explosion whistle should do no engine harm at light to moderate throttle at light engine loading, Running the spark a little late might modulate the sound and further reduce engine stress. I would not operate the whistle on a steep upgrade for more than a second or two.
The wolf whistle can be modulated using the throttle and the pull wire. A slightly richer than normal mixture might be a good idea if using the whistle a lot.
Post by Jerry VanOoteghem » Mon Jul 28, 2025 12:03 pm
George,
My take on this, is that your crank was about to break anyway if something that was essentially a misfire, caused by using an explosion whistle, was the last straw. I can see, however, that under a heavy load, the whistle did your engine no "favors". Probably a good idea to not use it under those circumstances.
Post by Jerry VanOoteghem » Mon Jul 28, 2025 12:15 pm
Willy,
If you're thinking of the Splitdorf plug with the whistle adapter, and you actually can find one, you're likely to end up with a used-up or "not so great" plug. These types of things work better as shelf decorations for spark plug collectors. In other words, it most likely will not be cheap and will also likely not work well.
As to the long reach plugs, for use in the more traditional style of explosion whistle, just be sure that the whistle adapter has room within it to accept the extra length.
WillyR
First Name: Vilhelm
Post by WillyR » Mon Jul 28, 2025 1:08 pm
I'd love to see a schematic, or have an example in my hot little hands to make my own, it wouldn't be above my abilities.
WillyR
First Name: Vilhelm
Post by WillyR » Mon Jul 28, 2025 1:22 pm
Willy,
I don't see using the whistle while climbing a hill or under a critical load.
Yeah, the existing modified plugs may very well be "used up" and that would explain why there are more whistles than modified plugs available on the ebays....
looking at online pictures of the adapter that is currently available....
I'm betting I could get it machined to sit deeper, and/or modify it to fit a long reach plug better/deeper into the chamber for more efficient combustion.... at least as good as stock combustion, or close enough that it won't matter.......
Post by TXGOAT2 » Mon Jul 28, 2025 2:39 pm
In making an adapter, I'd want to get the spark gap as close as possible to the stock position and keep the inside volume of the adapter on the cylinder side of the valve as small as possible.
Last Name: House
Post by George House » Tue Jul 29, 2025 1:58 pm
Jerry, that’s so ludicrous that you could assume a ‘misfire’ couldn’t cause a T crankshaft to break if it wasn’t previously weakened. You’d have no idea what condition my recently rebuilt engine was in back in 1976. Granted, I foolishly allowed 15-20 consecutive loud explosion whistles to fire off when the crankshaft broke. Learned my youthful lesson..
Post by Jerry VanOoteghem » Tue Jul 29, 2025 2:22 pm
Okay, so I'm ludicrous, so be it... Not sure why you need to be so defensive. Can I not have my own opinion, "ludicrous" as it may be?
BTW, do you think that every misfiring Model T will break a crankshaft?
WillyR
First Name: Vilhelm
Post by WillyR » Tue Jul 29, 2025 3:47 pm
If it's misfiring, it's still running....
WillyR
First Name: Vilhelm
Post by WillyR » Tue Jul 29, 2025 4:29 pm
I spoke with a gentleman at an online vendor and he had a suggestion for a plug to use with the adapter.....
If the experiment fails I'm out $15....
WillyR
First Name: Vilhelm
Post by WillyR » Wed Jul 30, 2025 2:14 pm
this is fun... learning more than I ever wanted to know about spark plugs.....
I'll order the adapter later today.
no luck finding a source for long reach 1/2" spark plugs.
-BUT- there are a plethora of long reach 14 mm plugs. 3/4" and 1"
once I get the adapter (and 14mm adapter) I'll see if a 14mm plug will reach far enough -AND- perform as well as a stock set of plugs...
-OR- a stock plug in the adapter... etc...
if none perform well for everyday use, then whichever performs good enough for parades will get used a couple times a year for parades..
Lessumner
First Name: Les
Last Name: Sumner
Post by Lessumner » Wed Jul 30, 2025 4:44 pm
One word of warning. Be care full how you route the wire you pull to operate the whistle. Spark plug wires bite!! Les
WillyR
First Name: Vilhelm
Post by WillyR » Wed Jul 30, 2025 5:18 pm
I'm proud of how I have my wolf whistle routed, maybe I'll post up how I did it.
I don't think I'll have a problem routing it around the plug wires, the T is one of the most neatly organized engine bays ever...
maybe I'll keep that on the passenger side just in case....
WillyR
First Name: Vilhelm
Post by WillyR » Tue Aug 05, 2025 9:34 am
I got the whistle adapter AND a 14mm plug adapter.
The longest reach 14mm plug I have found has just over 1" reach.
With the two adapters together the 1" reach just may be negated by the use of that second adapter.
I'm still going to buy a long reach 14mm plug. I'll swing by napa after work.
I will be plugging the whistle part of the adapter and comparing the stock plug and the 14mm plug and adapter for driveability.
I could machine the whistle adapter so the plug(s) sit closer to the combustion chamber, but I don't think it will be a significant amount.
adapter is 2" maybe I could trim it up to 1.5", I could trim up the 14mm adapter to sit flush within the whistle adapter, but still at best it would be 1.5" deep.
1” is the first mark/center
Second mark is how far I would be able to machine the adapter down. I could also remove the upper lip of the 14mm adapter and internally thread it to the whistle adapter.
WillyR
First Name: Vilhelm
Post by WillyR » Tue Aug 05, 2025 11:45 am
autolite 3095 is 1/2"-14 with a .84" reach... napa has them for $5.49 each... $21.96 for a set
champion 425 has a 1" reach but it's $39.99 EACH!!!
I may forego the 14mm plug and adapter and get a set of the autolites since the reach is close enough...
maybe when I'm rich I'll get a set of the champions.....
just realized I have no idea what I have in it now.... could already be a 1" reach....
I like having parts on the shelf anyway....
the 14mm NGK 4469 has a 1.043 in reach, but that would be negated by the unmodified adapter, AND it's $16.49 for one plug....
WillyR
First Name: Vilhelm
Post by WillyR » Tue Aug 05, 2025 9:52 pm
I have champion x plugs. They seem to be around .75”
Was at Napa 10 minutes before the closed and my plugs weren’t on yet.
https://youtube.com/shorts/DJ0p_K-4DUc? ... 7OLjYDwuyu
WillyR
First Name: Vilhelm
Post by WillyR » Wed Aug 06, 2025 9:16 am
re-post from my main thread....
I don't think the spark knew or cared that it was a 1/2" from where it used to be....
the drive in was unremarkable...
I'll pick up my spare autolite plugs and toss em' in with the other spare parts....
that was a lot of concern about nuthin'
WillyR
First Name: Vilhelm
Post by WillyR » Wed Aug 06, 2025 12:44 pm
I looked at the specs on the champion X spark plug...
I says they are 1" reach... I'm not sure if they are measuring base to tip or what, but that's not what I was measuring....
I was being generous saying it was 0.75"
I was going to just check the tuning with the adapter and plug off the whistle hole, but I couldn't find a plug for the whistle hole.
I had shot some used motor oil in the whistle mechanism last week, and had expected to have to take it apart and re-seal it, but it seems to be functioning perfectly....
I'm happy I got all the noise makers I have learned about, but so far this one is the least impressive sounding....
I don't know if I have a true favorite, maybe the bevins bermuda bell?
If the cutout for the aermore wasn't so leaky, it might be my favorite, but I haven't taken it back apart to see if my fix will work, maybe sunday?
Post by speedytinc » Thu Aug 07, 2025 8:18 am
Prototype/proof of concept. My answer to the unobtanium splitdorfs plug.
This will solve my & others rough running from the deep pocket of the brass adapter.
1/8" pipe adapter brazed to plug body.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Thu Aug 07, 2025 8:36 am
Speedy, that is gorgeous!
Post by speedytinc » Thu Aug 07, 2025 10:27 am
Thank you for the inspiration.
Post by TXGOAT2 » Thu Aug 07, 2025 12:45 pm
Be sure the cylinder is actually firing when the whistle is activated. I'd think it would be rather loud. I'd expect it to be a lot louder with more throttle opening since the volume and pressure of the combustion event would be a lot greater.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Aug 07, 2025 2:46 pm
I would be extremely interested in a step by step, with lots of pictures...
where and how are we drilling it?
Looks awesome!
Post by speedytinc » Thu Aug 07, 2025 2:55 pm
1/2" rod. Tapped 1/8 npt. Od cut down to .437. Thru drilled .156" Tapered lower section. Plug base clamped @ an angle. 3/8 end mill for the adapter piece to sit. Drilled .156 hole in plug base. Brazed together.
That ought to be enough info to reproduce.
Be careful to clear the base taper where the copper gasket sets.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Aug 07, 2025 3:38 pm
Thanks so much, I'll get started on those as soon as I can, is there a special recommendation on the plug used?
I have champion X plugs installed, but supposedly have some autolites coming from NAPA...
Post by speedytinc » Thu Aug 07, 2025 3:45 pm
Has to be a take apart plug I think. Champion X.
WillyR
First Name: Vilhelm
Post by WillyR » Thu Aug 07, 2025 3:50 pm
I never knew any plugs could be taken apart.... :lol:
WillyR
First Name: Vilhelm
Post by WillyR » Mon Aug 18, 2025 11:50 am
300+ mile report....
so with the stock .75" reach champion X plug there is zero noticeable change in performance.
I'll still research and convert a champion x or 3-4 plugs for use with the whistle.
