Torque tube...what's this?
Daisy Mae
Topic author - Posts: 522
- First Name: Kurt
- Last Name: Andersson
I don't recognize nor can fully make out the stamping on the torque tube flange..... anyone?
- Last Name: Tannehill
- Board Member Since: 2002
Re: Torque tube...what's this?
Patented? Maybe?
I'll second "PATENTED"...
ModelTWoods
- First Name: Terry
- Last Name: Woods
Whatever it is; the tube has been brazed, either to seal a leak or join two pieces from different tubes.
Since there dont appear to be rivets, which would have been brazed also, must been brazed only. I wouldnt assume it was repaired.
I have seen these early DS tubes cracked @ this joint.
Looks very authentic to me.
Daisy Mae
- First Name: Kurt
It's an early 2 piece tube
Interesting as to why it would have been stamped Patented.
Thanks...it's obvious now.... Doh!
- First Name: Adrian
- Last Name: Whiteman
The stamping goes over the brazing. My 'guess' here is someone with humour did the fix and said 'I will patent that repair
