FS Stewart speedo gears
Karl Von Neumann
Topic author - Posts: 892
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Stewart speedometer gear see pics for condition 40$ ea plus the ride
Re: FS Stewart speedo gears
Interesting gear with no spokes Karl. The block printing is early, as is the four hole mounting drilled into the bosses on the casting. Then it has also been drilled for a second four hole mounting. Using the lower right of these holes, two more have been drilled to make a three hole mounting like the later gears.
Allan from down under
