Matco Cross Drive Magneto Question
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Fri Sep 05, 2025 8:11 am
I got lucky this week a purchased this Matco magneto. The mag is hot and should clean up nicely. All the gears are there and appear in good shape. One thing I noticed that I thought was innovative is it’s set up for T engines with or without generator provisions.
The only thing that’s missing is the drive coupler. Looks like that will be easy to make. Just curious if anyone had a picture of the coupler so I can make it as close to original as possible? Thanks
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Matco Cross Drive Magneto Question
Post by Kevin Pharis » Fri Sep 05, 2025 10:10 am
Haven’t seen an output shaft with a hex drive before. Typically these MATCO drives have a 1” diameter cylindrical output shaft, and a matching hub to mount to the mag. A short piece of fiber reinforced rubber hose is used to couple. A 1/4” screw and nut anchors the hose at the output shaft side, and a special MATCO bronze hose clamp provides an infinite adjustability at the mag. I have drawings for the output shaft and bushing, can dig em up if you want
Post by Mark Gregush » Fri Sep 05, 2025 11:27 am
Same casting as my Eisemann front mount, including the provisions for use on both style engines.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Fri Sep 05, 2025 11:47 am
Kevin, the pictures I found online all had the hose type couplers, but none with the hex. I assumed this mag may be a later model since this mag has the impulse feature for better starting. But that’s only an assumption.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Fri Sep 05, 2025 12:55 pm
A love joy coupling may work for you
