I was just searching through my spare parts for some needed bits and found this part.
Here is a normal water inlet I found:
Here is the one I think is unusual.
It has a bump on the inside, the hole is not drilled through.
It has a bolt with what looks like a conduit clamp.
The only thing I can think of is a clamp for the horn wire, what's your guess? Have you ever seen one like this?
TH
What's this bolt for?
Thorlick
Topic author - Posts: 214
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
Re: What's this bolt for?
Model A's used a bolt there for the generator conduit. Could that be for a Model A?
Layden Butler
- First Name: Layden
- Last Name: Butler
Rich is right, Model A Ford.
Thorlick
- First Name: Terry
Thanks, I thought I had some sort of rare, unusual aftermarket T part. Instead it is a relatively worthless part from a gooney little known car!
(tongue firmly in cheek)TH
I am pretty sure I have one of those in my junk boxes if you need another?
Thorlick
- First Name: Terry
Thanks, Wayne, but I don’t wear ear rings!
TH
TH
