Lazy Outside Door Handle on 27 Coupe
ModelTWoods
Topic author - Posts: 1514
- First Name: Terry
- Last Name: Woods
I have a lazy, drooping outside door handle on a 27 coupe. Is there a way to rebuild the door opening/locking mechanism by replacing a spring, or do I need to replace the whole assembly? If my assembly can be repaired, how difficult a job is it?
Re: Lazy Outside Door Handle on 27 Coupe
Terry,
When the door is swung open, does the handle still droop, or does it only droop when the door is shut? If it always droops, then the trouble is likely within the door latch mechanism itself. If it only droops when shut, then I'm thinking that the latch bolt is not fully engaging with the striker in the door frame.
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Terry, this recent thread will be a big help if you need to rebuilt your latches:
viewtopic.php?f=2&t=48351
Edited to add a big Thank You! to Vern for taking the time and effort to document his latch rebuilt process so well!
Last edited by Shannon_in_Texas on Tue Nov 04, 2025 1:55 pm, edited 1 time in total.
Lang’s has 26-27 door latch repair repair kits. You can call them to see if the ones they have are for the closed car latches or open cars. https://www.modeltford.com/item/5679-80RK.aspx
Hope this helps.
Hope this helps.
