1925 pickup box
Rayboy
Topic author - Posts: 14
- First Name: Raymond
- Last Name: Hallett
- * REQUIRED* Type and Year of Model Ts owned: 1925 touring, 1917 runabout, 25 runabout
1925 pickup box
I have a 25 roadster and am looking for a pickup box. (25 preferable) Most of the ones I see are pretty rough. I really don’t have any idea how much they are worth. I just looked at one but it needs a ton of work. Any advice on value, condition, etc would be much appreciated. Thanks, Ray
Re: 1925 pickup box
A true '25 box is a rare item especially one not made into a trailer & beat to s _ _ t ! I've sold a couple nice ones over the last 30 years and they were both very nice & got $4-5 hundred. What is really hard to locate are the peculiar fender iron mounts - the later touring is compatible, but the tapered iron itself is not reproduced.
Re: 1925 pickup box
The correct 25 pickup fender irons have been reproduced. Contact Gator Gould. He used an original from me to make them.
Re: 1925 pickup box
Wasn't aware of that - thanks Larry !
Nunsio1
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Re: 1925 pickup box
If you cannot find a pick up box, I purchased a wood box ( large size ) from Snyders. It's installed on a 26 car chassis. Some work involved with assembly & stain and finish work, but went together well w/ good results in the end.
John M. Oscoda Michigan
Re: 1925 pickup box
I have a list that Trent found for me that gives all the parts required to install a factory pickup bed on a car. I wish I could put my hands on it!
