Timing mark
big2bird
First Name: Jeffrey
Last Name: Hausey
Timing mark
Post by big2bird » Fri Nov 28, 2025 4:36 pm
Has anyone ever set up a pointer/ mark on a T motor for TDC? Just asking, since I use a Bosch front plate.
Last Name: Hjortnaes
Re: Timing mark
Post by DHort » Fri Nov 28, 2025 5:26 pm
It has been done at the Speedster Reunion to get dynometer readings, so it should work for you.
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Re: Timing mark
Post by Dodge » Sat Nov 29, 2025 1:09 am
I just use a fine line paint pin and put a mark on the back of the pulley and the timing cover.
AndyClary
First Name: Andrew
Last Name: Clary
Re: Timing mark
Post by AndyClary » Sat Nov 29, 2025 10:05 am
If you have an aluminum pulley you can use the split for a timing mark. On stock pulleys on run the paint marks around the back a little away from the belt.
Andy
Re: Timing mark
Post by Jerry VanOoteghem » Sat Nov 29, 2025 10:50 am
Andy
True! And very handy. Just be sure when you install the pulley to align the split with #1 TDC and not BDC, (bottom-dead-center).
