Magneto
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
Board Member Since: 2012
Magneto
Post by Oldrusty26 » Fri Jan 09, 2026 11:02 am
Another question for the team, when recharging the magnets on a magneto in the car, do you have to touch each magnet individually or just at the mag post? i’m working on a 1925. I have the hogs head off to inspect the coil rings. Everything looks good but the mags are weak. I was planning on doing the flash charge with a DC welder.
Thank you
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Magneto
Post by Rich P. Bingham » Fri Jan 09, 2026 12:52 pm
Search this forum for the proper procedure for re-charging magnets in an assembled engine. It’s done through the block-mounted coil ring, the transmission cover needs to be on so a compass can be used to properly orient the flywheel. Many say the engine should be aligned with magnetic north, there will be advice on how to use a welder as a power source.
Good luck, and be careful ! (enjoy your T ! :D )
Get a horse !
Last Name: Kuehn
Re: Magneto
Post by John kuehn » Fri Jan 09, 2026 1:04 pm
Here’s a good forum post about charging the Magneto in the car. http://www.mtfca.com/discus/messages/506218/528397.html
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 12:39 pm
Thanks , hopefully it will be done today!!
First Name: john
Last Name: karvaly
Re: Magneto
Post by speedytinc » Sat Jan 10, 2026 1:01 pm
The compass method assures that (A) a coil is centered over the magnet ends & (B) correct polarity.
Physically looking @ the position of the magnet keeper screws thru the inspection cover will, even more accurately cover (A).
Polarity is not important with a saturation re-charge. However if you dont believe the exhaustive testing Tom C. did in this regard, use you compass to confirm polarity after sighting the magnet keeper screws. Have the car pointing in an East/West direction.
Definitely read Tom C's posts. His method is proven, works great.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 7:59 pm
I set the chassis east and west , used a compass to determine north and south . Ended up using the 3 battery set up to flash with the positive on the solder button and striking ground to the engine block , it worked somewhat , but the magnets aren’t as strong as I feel they should be , but they’re stronger than they were if that makes sense .
First Name: john
Last Name: karvaly
Re: Magneto
Post by speedytinc » Sat Jan 10, 2026 8:35 pm
Did you line up the magnet screws as I suggested? 3 batteries isnt enough for a saturation charge. A high output dc power source from a welder works best In my experience.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 9:26 pm
I’m going to try the welder tomorrow, I’ll post my results . Thanks !!
Re: Magneto
Post by Scott_Conger » Sat Jan 10, 2026 10:08 pm
When you're done with the magnets, don't ignore the bands and band material which all look to need attention, as well as possible two-piece valves.
Be careful about stacking loose things around that abyss - it's no fun fishing parts out and even less fun starting the car up and finding out you should have spent more time fishing.
Oldrusty26
First Name: Travis
Last Name: Melnick
Re: Magneto
Post by Oldrusty26 » Sat Jan 10, 2026 10:36 pm
Very good advice !! I will definitely clean up the area before moving forward , I pulled this unit out of a barn quite a few years ago and am looking forward to getting it back together . They are the two piece valves , the whole thing needs cleaned up and out .
