Have I ever said I hate nightmares??
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Tue Jan 13, 2026 11:27 am
I generally don't recall my dreams, but this morning I woke up like I'd been poked with a cattle prod!
I had recently rebuilt my rear axle. Through all the various test fits setting thrust bearings and gear lash, while I had torqued down the pinion gear, I had left it unpinned intending to do it with final fitment. Generally, I'm always very anal with process (even as a kid building models, but I was also a network engineer with AT&T with plenty of time spent in Bell Labs development, writing process M&P's, teaching, etc, so, kind of ingrained). So there must be a reason why my mind kicked me upside the head this morning screaming "ya dummy!!!!"
Ugh....now I'm paranoid.... I can't imagine I failed to pin it, but neither can I now recall with certainty being suddenly clouded by doubt. I'm looking at it now not wanting to hoist it back up on the bench and completely undo/redo the whole thing.....but....neither do I want to live in fear of a broken/locked up axle, that would be the worst potential.
So....no choice but here we go again.....
If I find it is pinned, I'll be mad and will give my subconscious a serious piece of my mind!!!
Ugh....have I ever mentioned how much I hate my nightmares???
varmint
First Name: Vernon
Last Name: Worley
Re: Have I ever said I hate nightmares??
Post by varmint » Tue Jan 13, 2026 11:45 am
So, I'm not the only one wondering if I turned the fuel lever off on the sediment bowl, switched off the battery, set the parking brake, and locked the door to the garage. Saturday, on a different engine fresh rebuild, I put in a quart of oil, only to hear a familiar streaming-dripping noise.
In my humble opinion, your pinion has me beat.
Vern (Vieux Carre)
Post by Jerry VanOoteghem » Tue Jan 13, 2026 11:52 am
Those thoughts usually come rushing into my head at 2:30AM. It's a magical time of night, when my subconscious mind decides to question everything I've ever done. :o Not going back to sleep after that.
Post by Scott_Conger » Tue Jan 13, 2026 11:55 am
the only thing I think about at 2:30 in the morning is: "did I lift the lid?"
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 12:02 pm
I'm now realizing being anal with an evil minded paranoid subconscious does NOT make a good combination!
My ego of youth never allowed such doubt to ever disturb my beauty sleep.... this is new uncharted waters for me as I creep up in years....at the moment I'm discounting the side of me screaming "WARNING WILL ROBINSON!!"
...but....
I'll report on which side of my brain was being truthful when I crack the axle open....
Post by speedytinc » Tue Jan 13, 2026 12:08 pm
I wonder if a bore scope could save you a lot of work.
Post by TXGOAT2 » Tue Jan 13, 2026 12:34 pm
When even your hairdresser doesn't know for sure....
Last Name: Hatch
Post by Dan Hatch » Tue Jan 13, 2026 12:35 pm
Don’t worry about it!! I know a guy that has some 14 rear end parts. And he is not that far from you!!!!
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 12:36 pm
Hey John, I actually thought of that, but neither am I aware of who/how/where I can access one. Thought of a plumber, but didn't think they'd be small enough....
Something to look into, or, maybe some of ya'll have suggestions....
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 12:40 pm
Dan.... :lol:
And who might that be???
I already bought one spare axle from you....
You wanting to sell me that Rux??
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 12:44 pm
Hmmm...OK so I just looked.... $32-$80 either Wallyworld or China Harbor.....
Mama just shakes her head everytime I say I need a new tool!!!
I might just need that!!! Better than needlessly cracking the egg....
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Jan 13, 2026 12:48 pm
Kurt, you can get a Depstech bore scope for $70 online. I have one and it works great.
Post by speedytinc » Tue Jan 13, 2026 12:55 pm
I have the same one. Is a self contained unit.
There are cheaper versions that use your cell phone for the screen.
Paid for itself @ the first transmission fishing expedition.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 1:09 pm
Thanks ya'll!!!!!
Who doesn't love a new tool?
I might just end up loving my evil paranoid side!
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Tue Jan 13, 2026 1:28 pm
Daisy ,
If you can find a scope that has a probe end small enough to fit through a piñon spool bolt or stud hole first try using the fill plug hole to get access to see piñon nut. If that doesn’t work you can try using the bolt hole it should place the scope head right above the piñon bolt nut for an easy look down to see yes or no on installation of split pin .
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 1:34 pm
Great idea Kevin, here I've been thinking about having to bend/snake/contort thru the drain hole around the carrier, but that's a straight shot if it fits!!! Hadn't yet thought of that.
Now to get specs on camera head/snake diameter....
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 2:13 pm
So...
The restriction would be the threaded portion of the housing for the spool stud, being the narrowest point.
The camera head diameter on the Depstech is 7.9mm....
I just mic'd several of the old spool stud nuts at ID 8.5mm tightest to 8.85 worn..... WOOT!!! We have a go for launch!!
Post by Allan » Tue Jan 13, 2026 4:10 pm
I can't tell from your text if the assembly is back in the car. If not, just undo the front nuts on the radius rods and the 6 spool bolts and slide the driveshaft assembly forward.
Post by John kuehn » Tue Jan 13, 2026 4:32 pm
I think we all have forgotten to put a piece or part in! When I put the engine together for my 21 Touring I was ready to put it in the car I got to thinking that I may or may not have installed the internal oil line that bolts on the mag coil ring mount to the front main. Sure enough I looked around the shop and there it was!! So another half tare down began dang it!! From then on I learned to double check when putting engines and etc together.
And I thought I did but not this time.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 4:55 pm
Allan,
Still sitting in a cradle.
That would be my hope for easiest path if I have to check by pulling, or, to fix if need be.
But the housings once bolted down clamps the spool sleeve pretty tight. If I had to back off the housing bolts to release tension my fear would be it would be enough to break the gasket seal, where, if that was the path, my anal side would be screaming at me to pop & redo.....
Then again.... oil leak....on a T...Really?? so what. :lol:
Post by TRDxB2 » Tue Jan 13, 2026 9:19 pm
One nightmare begets another unless you resolve the issue by inspecting the pin's presence. If find it was there you'll have a good laugh, If not you'll feel very relived that you did check. The longer you wait the more sleepless nights.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Jan 13, 2026 10:44 pm
Scope is on order from Amazon....figure I can wait a few days before cracking the egg.
Post by Allan » Wed Jan 14, 2026 6:37 pm
The halves should not clamp on the bearing spool, especially if you used a paper gasket beyween the halves. If it is tight relax the diff half bolts a turn or two. You cn use the back bolts on the radius rods to drive the housong forward.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Wed Jan 14, 2026 7:51 pm
When I get jolted awake @ night it might be from several reasons, in order of occurrence.
1) My 90lb dog has decided to use me as a pillow and I am being crushed under a heating blanket.
2) Time for a trip to the bathroom.
3) I got a cramp because I was sleeping in a weird position.
4) Something I forgot to do, need to do, something coming up I forgot about.
5) I figured out how to solve a problem, create a test to diagnose a problem, design something, generally something I was stuck on during the day.
There is a pad and pen near my pillow because remembering what I thought of doesn't always happen.
Remembering you had a great, or not great, thought but not remembering what it was is very frustrating.
Mike
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Wed Jan 14, 2026 8:29 pm
I was thinking the same thing. Go in through the fill plug down over the top of the carrier, should be able to see it.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Thu Jan 15, 2026 1:02 am
Thanks Allan, I hadnt considered using the back bolts to draw forward.
This was my first T car axle I've rebuilt, my TT Worm being my only other T axle rebuild. When I tore down the axle, the torque tube would not release until I had taken all tension off the halves. I figured rust/corrosion etc. But with cleaned/new parts, and nothing apparent as to anything out of round, neither would the torque tube slip into the halves when bolted together (and yes, with paper gasket), I had to fit everything loose, and then torque down.
Being my first, I wasn't aware if that was normal or not, but, have known a lot of assemblies to be that way.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Fri Jan 16, 2026 11:10 pm
This is a heredity thing between family members. Between my nephew and me he being 20 years younger than me, we both seem to wake up within 20 mins of each other to drain the radiator. Usually plus or minus 3 am.
The worst part is back in bed the mind turns on and problems or questions began filtering through the mind not allowing a quick return to sleep.
Damn near a nightly thing.
just sayin'
frontyboy
Post by Mark Gregush » Sat Jan 17, 2026 12:42 pm
I have nightmares about getting the ring gear on the correct side and if the cam/crank gear dots are lined up. :?
