Need to make parts for a manifold heater
Reno Speedster
Topic author - Posts: 640
- First Name: Morgan
- Last Name: Blanchard
I just bought a really nice manifold heater. It is straight as a die and the exhaust pipe threads are perfect. The screws holding the tins on came right out. It did not come with the parts that go in the floorboard so I have to find or make them. I have looked at different ones in the forum and other places and I don’t see one quite like this. It has a very small outlet that does not seem to be like those others I have seen. I can’t figure out how it would connect to the vent in the floor. Any hints?
I do have the sheet metal cover, just not on in the shot.
Re: Need to make parts for a manifold heater
Looks like someone added a shield for the F/W. The normal heat pickup covers all those finns.
Keep looking for examples & the design will be come obvious.
I'll get some photos of mine for you. I also have an extra floor register.
From an old postReno Speedster wrote: ↑Sat Jan 24, 2026 9:15 pmI just bought a really nice manifold heater. It is straight as a die and the exhaust pipe threads are perfect. The screws holding the tins on came right out. It did not come with the parts that go in the floorboard so I have to find or make them. I have looked at different ones in the forum and other places and I don’t see one quite like this. It has a very small outlet that does not seem to be like those others I have seen. I can’t figure out how it would connect to the vent in the floor. Any hints?
Reno Speedster
I saw the old post and mine is like the top example. I have all the tins, I just took them off to check it out and clean out the wasp nest. But, as I said, it does not match the drawing.
There were several manufacturers of those types of heaters - the silver shroud one is on our'19 Centerdoor - photos coming.
Some pics of registers for those heaters.
Floor board install
Have one of these registers in my stash if you need one, may be useful for your install.
Floor board install
Looks like a prolific source of squeaks. I wonder if a flex coupling for the register could be made from the material they make oven door gaskets from. (?)
Like you could actually hear a "squeak" over the engine noise & knarly planetary ?
You could in my car.
Mark Nunn
- Last Name: Nunn
Rich Eagle made a vent for his heater. See the posts starting around Feb 8.
https://mtfca.com/phpBB3/viewtopic.php?t=371
Reno Speedster
Thanks guys. I got a register on the way in the post. I will clean things up and get the manifold ready to go on the 22 in the spring. I have a Z head to go on it and a few other things to do when the weather gets better. I have a zenith carb and intake I might try as well. My 22 is a rolling accessory magnet.
