Hey, can anyone in the group share the known measurements of the Model T transmission early Brake Drum "Top-Hat" bearing? I see some of them given by Benson Archives parts listing pages, but would prefer to have actual measurements, even if a little worn.
Thanks,
Jim Key
Accurate Models
Need Model T transmission "Top-Hat" bearing measurments
accuratemodelmaker
Topic author - Posts: 17
- First Name: Jim
- Last Name: Key
- * REQUIRED* Type and Year of Model Ts owned: 1915
Re: Need Model T transmission "Top-Hat" bearing measurments
I have a NOS one - be tomorrow before I get back out to the shop.
.111, .111. & .112. all used measured in an area with no wear.
accuratemodelmaker
- First Name: Jim
- Last Name: Key
Hmm, that's interesting, given that the call-outs for the flange have been 1 & 39/64" (1.609375"). I took and subtracted the bushing (1.50?) from the flange and got .109375" as a remainder. Reading other threads, I remembered .110", so your measurement of .111", .111", .112" seem to bear out those previous postings. This is important because looking over the Benson archive parts prints, The early Brake Drum shaft is shown to be a total of 4.686" to 4.689". The later shaft is 4.670" to 4.676" - .010" to .019" of an inch shorter. I suspect it has a lot to do with replacing the Top Hat bearing with the 3 thrust washers.
Still need depth (back of flange face to opposite edge (1.50"?)
OD of bushing (1.185"?) ID of bushing (1.002 to 1.004"?)
OD of flange (2.375"?)
Thanks in advance for all assistance. New plans for preview soon, as I've completed quite a bit, as well as 3D.
Jim Key
Accurate Models
Jim Key
Accurate Models
