Blockley question
Will
Topic author - Posts: 192
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Blockley question
This morning while checking the tire pressure I found a screw in my Blockley front tire. I guess it didn't make to the tube as the still had good air pressure and who knows how long its been in there. It renewed my faith in the Blockley tires and tubes. I bought these tires a couple years ago before all the issues with shipping. I'm going to order some more tubes and tires and would like a heads up the new steps I need to take to get everything.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
- Last Name: Hatch
Re: Blockley question
From my experience: If UPS sends you any emails about forms for the tariff. DO NOT SEND ANYTHING TO UPS TILL YOU TALK TO BLOCKLEY. I screwed up and ask UPS a question and it messed up my delivery. Talk to Blockley first. Dan
I wish Blockley would make tubes with rubber valve stems, so we could cut them off and install the correct ones.
- Last Name: Juhl
Larry - most of us are quite content to have blockley tubes complete with their high-quality, factory mounted brass valve stems. When you put a cap on it you can't see the valve stem anyway.
- Last Name: Hatch
Will sent you an answer by the forum. Dan
