Wanted: original 1914 Ford coil box lid
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Mon Mar 09, 2026 9:04 pm
I purchased a new repro lid for my 1914 T awhile back. When I installed the coils, the lid would not close all the way. Now I have to drive with the coil box lid off. I am using original metal top coils. I set the metal top coils along side of a later ford coil and the metal top coil is much taller then the other. Now I am in the market for an original coil box lid for the 1914 coil box. Anyone out there have one?
Contact me through the forum.
Craig E. Luton
First Name: Craig
Last Name: Luton
Re: Wanted: original 1914 Ford coil box lid
Post by Craig E. Luton » Fri Mar 13, 2026 1:27 pm
to the top please
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Mon Mar 16, 2026 3:12 pm
There must be one out there some place.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Thu Mar 19, 2026 9:53 pm
to the top please
Craig E. Luton
First Name: Craig
Last Name: Luton
to the top please
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Fri Mar 20, 2026 12:29 pm
Are you looking for the single piece slanted one? Or the flat top?
Post by RajoRacer » Fri Mar 20, 2026 12:57 pm
'14 is a flat top !
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Fri Mar 20, 2026 1:11 pm
Karl, Yes, the 1914 coil box lid is a flat top one like Steve said.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Mar 20, 2026 1:16 pm
Ok 👌 just checking looking for a flat top my self i ended up getting a single piece slated one thinking I might cut it flat to fit mine
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Fri Mar 20, 2026 3:30 pm
Karl; Sounds like you have a 15/16 coil box lid if it is one piece.
Post by RajoRacer » Sat Mar 21, 2026 7:22 pm
Sent you an email w/photos, Craig
