TT latch spring
Ottoparts
Topic author - Posts: 11
- First Name: Chris
- Last Name: Otto
- * REQUIRED* Type and Year of Model Ts owned: 1921
TT latch spring
Started working on my latches for my TT doors. That was fun and itself. The latches are now tore apart, unfrozen and glass beaded to remove rust. I bought a door latch kit thinking that the springs or the same. As you can see in the attached pictures they indeed are not. I'm not having any luck so do any of you out there know of a place that sells TT door latch springs?
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: TT latch spring
I can't tell which spring you need?
Just show the one you want. Then show it with a coin the same size as the "snail" part. Also, measure the steel spring stock dimensions so it will fit into the mechanism. I have some trays of door lock spring assortments for cars of the 20's, 30's and 40's.
For example, I have found that a spring for a 1939 Chrysler works perfectly in the latch on 1914 touring and roadster.
1922 Coupe , 1926 Touring
Ottoparts
- First Name: Chris
- Last Name: Otto
Re: TT latch spring
I'm not sure what you mean by measure the stock spring. I did take pictures with a quarter. The quarter is on top, besides, and underneath the spring.
Jim, Sr.
- Last Name: Rodell
Re: TT latch spring
Chris,
I will check to see if I have those springs tomorrow.
Ottoparts
- First Name: Chris
- Last Name: Otto
Re: TT latch spring
Thank you for the help Jim.
Jim, Sr.
- Last Name: Rodell
Re: TT latch spring
Chris,
I checked all of my latch springs, but none matched yours
I'm sorry that I can't help.
Ottoparts
- First Name: Chris
- Last Name: Otto
Re: TT latch spring
No problem Jim. Thank you for taking the time to look.
