Pressure testing blocks.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Sun Jul 21, 2019 8:45 pm
I thought some might be interested in how we pressure test model T’s. Every block and head that comes out of here goes through this. It’s very simple to do but it has prevented quite a few flawed parts from being sent out the door only to cause problems later.
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1924 Speedster Gow Job
Re: Pressure testing blocks.
Post by Chad_Marcheese » Sun Jul 21, 2019 9:26 pm
What pressure do you pressurize them too?
Tbz4u
Last Name: Weitzel
* REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
Post by Tbz4u » Sun Jul 21, 2019 9:29 pm
I believe 10 psi. And thats a lot in my opinon then let sit and inspect
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Sun Jul 21, 2019 10:57 pm
How high can combustion pressures get in older engines?
I have an off topic engine that has a notorious reputation for weak upper combustion chambers, side mounted head and this setup is exactly what I was looking for with all the details Erik! Thank you.
Post by Mark Gregush » Mon Jul 22, 2019 1:46 am
I made something like that but added a pressure gauge.
Last Name: Hatch
Post by Dan Hatch » Mon Jul 22, 2019 7:04 am
There is a plate made that has cutouts for the valves and clys for sale at a vendor. Let’s you look at the top of block or head while you test it. Dan
