What part of a T are theses?
Last Name: Hatch
Post by Dan Hatch » Sun Jul 21, 2019 7:55 pm
I have a lot of NOS double threaded studs that are 3/8” SAE thread both ends, about 2 1/4” long, only cotter pin hole in ONE end. Does anyone know what part number they are or where they go on a T? Thanks Dan
Mark Nunn
Last Name: Nunn
Re: What part of a T are theses?
Post by Mark Nunn » Sun Jul 21, 2019 10:47 pm
I'm guessing but I think they are radius rod ball cap studs. The holes are for safety wire, not cotter pin.
Post by Allan » Mon Jul 22, 2019 6:31 am
The fine thread each end is found on manifold studs, but they are not drilled for a split pin.
The front radius rod ball cap studs on our Canadian sourced cars have a coarse thread on the pan end.
The radiator mounting studs are drilled for split pins both ends.
I can't think of any other studs used on T's.
Last Name: Hatch
Post by Dan Hatch » Mon Jul 22, 2019 7:00 am
These are not radius rod cap studs, they are NC one side. These are same size as rad studs but only one hole. Maybe after market? Dan
Post by RajoRacer » Mon Jul 22, 2019 11:10 am
Perhaps early valve cover plate studs ????????
Post by Original Smith » Mon Jul 22, 2019 12:35 pm
Now Steve, you know better than that!
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Mon Jul 22, 2019 1:20 pm
Hi Dan,
I believe that what you have there ARE front radius rod ball cap studs used only on the 1909 and 1910 cars. I am sure that the Ford engineers had a good reason to make the change. Best Regards, Bill
Bill Harper
Keene, New Hampshire
Last Name: Hatch
Post by Dan Hatch » Mon Jul 22, 2019 1:34 pm
Bill. That appears to be the answer, you are the second person to say that. If anyone needs any email me. Dan
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Mon Jul 22, 2019 1:48 pm
Could also be the studs in the early differential housings, Bob
Post by RajoRacer » Mon Jul 22, 2019 4:10 pm
I know Larry - :roll: I have a number of the same studs that Otis had machined.
