Starting crank arm question
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Tue Jul 16, 2019 5:09 pm
Is there supposed to be a small hole near the end of the starting crank arm for the spring to attach to? I can't seem to find one on mine, but it's been recently painted and I don't know if the hole was filled in with paint.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: Starting crank arm question
Post by FATMAN » Tue Jul 16, 2019 5:28 pm
Yes they all have a hole 5 3/4" from the end on the right side in line with bottom of the hole, Bob
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Tue Jul 16, 2019 5:32 pm
Thanks, Bob, that's kinda what I thought but couldn't remember exactly where the hole was; your photos and measurements helped tremendously!
Post by Steve Jelf » Wed Jul 17, 2019 12:17 am
It's very common for that hole to be so filled with paint and/or crud that it's hard to find.
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Wed Jul 17, 2019 10:03 am
Alright, now that I've finally located the hole is there a trick to getting that spring on??? It's brand new so it's pretty stiff.
J1MGolden
Last Name: Golden
Post by J1MGolden » Mon Jul 22, 2019 6:47 am
I had difficulty with adding the new spring and realized the end that is bent over is longer than required.
Grinding off half the length made it much easier to replace.
J1MGolden
Last Name: Golden
Post by J1MGolden » Mon Jul 22, 2019 6:48 am
J1MGolden
Last Name: Golden
Post by J1MGolden » Mon Jul 22, 2019 6:49 am
The above message was just a rest, but I over did it.
Nice to see this 2019 Forum actually working again!
