flywheel magnets
Topic author - Posts: 20
- First Name: Jim
- Last Name: Boyer
- * REQUIRED* Type and Year of Model Ts owned: 1927 T truck. 1927 T roadster
flywheel magnets
Has any one researched what kind of steel is used in the magnets for the alternator on the model T? It would be interesting to try to make one. Your input would be appreciated. Thanks Jim
- First Name: Douglas
- Last Name: Keppler
Re: flywheel magnets
I believe it was a very attractive metal Jim
1924 Touring car
There's No Substitute for Proper Lubrication
Doug, do you need to be put in "time out"?
- Last Name: Hjortnaes
Model T's do not have alternators
Check this out, he is using Rare Earth Magnets;
viewtopic.php?t=1109
RE; "Model T's do not have alternators"
While it does not have diodes to convert to DC it does produce AC current. So it is a form of alternator.
Unless of course you add diodes to charge the battery.
- First Name: Jim
- Last Name: Boyer
I guess I should of said flywheel magnets not alternator magnets.
Murray Fahnestock's article on magneto for FordOwner magazine describes the magnets as tungsten steel.
Forged to shape and then heat quenched.
And here is discussion on a modern version:
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=1109
