I drove my TT for the second time.
Topic author - Posts: 10
- First Name: Duane
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1927 TT
I got my 27 TT out for the second time this weekend. Wow do I need to practice driving it. Fortunately I have a parking lot to practice in. I start out fine and travel along just fine however my stops or not so graceful. I cannot stop with killing the engine. I am pushing halfway down on the far left pedal and all the way down on the right pedal and I kill it every time.
I am very new to the model T world. Until November I had never even ridden in one so I have a lot to learn.
Also when moving along and going to high range the transmission sounds noisy. The noise is gear noise like an old transmission sounds but seems excessive. How concerned should I be?
Any of you in southern Indiana? I would like an experienced T person to drive it and make sure all
Pedals are adjusted properly.
Re: I drove my TT for the second time.
Try taking the truck out of gear with the hand lever when you stop. Straight up should be neutral. Don't worry about learning to drive. Millions of people have done it, and you're smarter than some of them.
- First Name: Henry
- Last Name: Petrino
Duane,
You don't say whether or not your truck has an auxiliary transmission. Typically, the "gear noise like an old transmission" originates in an aftermarket unit and is pretty common.
In addition to what Steve suggests you might also try going from high to low (left pedal all the way down) "easy" (don't just jam it down suddenly but do go all the way down to not slip the band too much ) slowing the truck then back up to the half way (neutral) position as you apply the brake (right pedal).
God luck!!
God luck!!
- Last Name: House
Your noisy transmission is most likely worn out triple gear bushings. When driving in the large parking lot in high gear slowly push down on the clutch pedal and increase throttle until truck has no forward motion and engine is running a fairly high RPM. That clutch pedal feeling will be neutral. It’ll probably need some adjustment. What do you know about the engine/tranny rebuild status ??
- First Name: Duane
- Last Name: Davis
I really don’t know much about the engine and tranny rebuild. The only thing I know is that a couple of guys that heard it start and run were really impressed how well it started and ran, and how quiet it was.
- First Name: Duane
- Last Name: Davis
Yes it does have an auxiliary transmission. It doesn’t sound like the sound is coming from there but it certainly may be. I will try theses suggestions soon.
- First Name: Dallas
- Last Name: Landers
My TT has a Chicago 3 speed aux. Trans. Straight drive which is normal T trans is quiet. Overdrive and under drive in the Chicago is pretty noisey. See that your aux. Trans is in straight or direct drive. What type aux trans is in your TT?
- First Name: Henry
Duane,
My TT has a Muncie aux tranny. It growls like an old dog. Even without knowing what type of aux tranny your truck has, my money is on it as the source of the noise.
I'm with Henry on this
And unless you want to quit having fun and do exploratory surgery (which may or may not result in a silent transmission), I'd drive it that way. Those old transmissions sometimes made that kind of whining noise on their best day out of the factory.
Avoid the temptation to dismantle anything that doesn't seem right (unless absolutely sure). It is a T, not a Honda. With no disrespect intended, the younger you are, the worse these things sound: For one, you've never experienced something like it, and two, your hearing is still good...
- First Name: Henry
Scott's comments are spot on. I've been riding in my TT since I was a baby in arms (it was my grandfathers TT). That tranny has growled for over 65 years (I'm now 71) that I personally remember. Drive it and don't worry. If it quits you'll know it.
- First Name: Adrian
- Last Name: Whiteman
Hi Duane,
Welcome to the hobby. Be careful, often the first T leads to a second!!
I had to learn to drive my truck much as you are doing. Just keep on practising.
I would suggest 'ignoring' the aux trans at first - what I mean is don't try changing gears in it, just focus on getting the basic pedal operation smooth.
I am not familiar with your aux transmission, but check if it is possible to get it into neutral. If so BEWARE as your brake is in the standard transmission, and getting the aux in neutral means you have no effective brake. The hand brake may slow you down a bit but don't rely on it.
I found using the hand brake 'half way' like Steve suggested was a good way to start, then progress to Georges' suggestion until you get the feel for the pedals. At the end of the day, what works for you works.
Remember, millions of folk learned to drive the T and you can too, it just takes practice
Keep up the good work, and maybe a photo or two as well?
Cheers
Adrian Whiteman, New Zealand
Cheers
- Last Name: House
Yeah; you ought to hear the stock transmissions at The Henry Ford. Growled like a Godzilla movie. Adrian (above) is spot on. Develop the many driving techniques a T requires. Just don’t expect to keep up with T cars. A former 2 time MTFCA president tried to with his TT. Blew up 2 engines.
George
some learn by education
some learn by doing
some learn through tragedy...that's the most expensive education of all
some learn by doing
Scott,
You forgot the last bit:
'Sadly some just don't seem to learn at all!'
Usually they are they ones who never ask and if they do they never listen, and in any case they already know it all anyway.
Ah well, life is interesting
- First Name: Duane
- Last Name: Davis
Report back and post more pictures.
Somebody replied that I had better be careful because I could become a T addict. I think it may be to late. I have several hot rods and classic cars but this old truck is quickly becoming my favorite.
drool..
I do like trucks!
Glad to hear you are enjoying it
I do like trucks!
Now THAT is a GREAT truck!
Even I might be converted with something like THAT!
- First Name: Adam
- Last Name: Doleshal
If its the same truck, it belonged to someone around Wales, Wisconsin about 25 years ago. Looks like the same one.
Big, Green and really cool. You guys know I like it!
Ha ha - I wonder whyBig, Green and really cool. You guys know I like it!
cheers
Adrian
- First Name: Bruce
- Last Name: Carswell
- * REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Duane,
I see your TT is a former REA truck. This is very cool as I am actually restoring my 24 TT C cab as an REA (actually its predecessor American Railway Express). Any pictures you could post/send on details such as lettering etc would be appreciated.
Bruce Carswell
Bruce Carswell
- First Name: Duane
- Last Name: Cooley
Duane, you have fun at the NSRA Nationals! That truck will wait for you. Quite patiently, in fact.
What an absolutely beautiful truck! And I thought my Lucky was a good lookin' ol' devil that has no view behind without a huge mirror.
Around the yard, I keep the Warford in low (under drive). Like Steve suggested, perhaps get used to pulling the controller/hand lever back to neutral for a bit. I still do sometimes in all three runners here.
I drove a gorgeous T snowmobile one time, couldn't find neutral with the pedal either. I didn't have the time to straighten that one out.
It isn't easy being green. Just ask Kermit.
Hehehe. It's different typing my own name to another T fellow.
I know of three of us here.
Oop, then there's the confusion between Duey C and Mr David Dewey here too sometimes.
Du
Du
