What is the trick to hook up a horn button?
Topic author - Posts: 2882
- Last Name: Hjortnaes
I can try to get the wires attached in the horn button, although their is not much space to attach the wires to their posts.
Cn anyone show an easie wAY to get this to work. attaching to the horn nd batery is simply straight forwrd, but then trying to get the horn bottun functuioning propabiy need some trining. Doues nyone have short video o step by bstep produntion.
Thank you.
Thank you.
Re: What is the trick to hook up a horn button?
David
Here's some tips and a how-top-do with photos.
https://nebula.wsimg.com/8a22557c16477a ... 31FDB20580
Dan
Would you be able to update the above website?
Thank you.
Dave
Thank you.
Dave
Dave
That page is latest no update.
Sent you a pm as perhaps the link won’t open for you.
Dan
Dan
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Dan,
Thank you for posting the step-by-step with photos.
Only took me 30 minutes to install a new horn button by not using those steps.
I had to go to confession at my local church for using very bad language while doing the installation.
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Henry
- Last Name: Lee
Gene,
Stand on your head, Lift left foot up 6" not to exceed 8", point your tongue towards Alabama, Say "Mississippi" one hundred and two times...., Done Baby!
Dan
Thank you for the PM. I did not realize that the MTFCI website had your articles in the hot links on the main page. Maybe I should look at their website a bit more often.
I probably spent 3 hours today trying to get that horn button put together. It was on there before, but sure does not want to go back on now. I replaced the wires, and when it is together the button moves about 10 thousands. I have to find a way to get it together so the button works. I might have to try the upholstery tack method that you used. Can't hurt.
Thank you for your help.
https://www.modeltford.com/item/A-BUT.aspx
I wonder if it would be easier to install this button instead of the original.
Has anyone else done that?
