I placed two arms in boxes, because the arm changed in 1909 from 1/2 inch roller to a 5/8 inch roller later in that year, but both were used and in the Ford Parts catalog from 1909-1911...this changed in late 1911-1912 (about 6 weeks worth) when Ford tried the "Oil Fill" timer. Most of the commutators you see online for sale, that have no flange like this one does, yet have the spring arm are not 1909-1911's as they advertise they are, they're 1912 and they have no flange because they're for use with the oil fill timer. since oil needed to get around the commutator, the flange had to be removed which meant that the felt seal and its support washer were also unneeded and in the way of oil getting into the engine (as was the timer shield too for that matter) and the camshaft nut couldn't hold the timer to the engine any more, so Ford used the bolt and strap like on all later Model T's.
I tell you that just knowing this explains a lot about how the evolution of the Model T progressed, I've said it several times, that I'm in a rather unique situation in that I get to see the progression of the improvements and how they came about from 1909 thru 1927, and hopefully you will too.
Of course the next one will be the Oil Fill Timer...fun never quits!.
