Cowl Lacing
Topic author - Posts: 326
- First Name: GG
- Last Name: Gregory
Cowl Lacing
How's the best way to install new Cowl Lacing on a 27 Roadster ? The old lacing was held in place with small ring shank nails through tiny new holes made into the Cowl....yes I know that's not the correct way. I'm lost at how to keep the lacing lined up and drilling the hole through it for rivets.
- Last Name: Humble
Re: Cowl Lacing
If I remember right it is held in place by spiral shank nails.
- First Name: Jim
- Last Name: Sims
Re: Cowl Lacing
Should be held on with split rivets. The heads are inside the cowl and the split part is outside. Almost impossible to install with the gas tank in place.
- First Name: GG
Re: Cowl Lacing
The gas tank is out.
- First Name: GG
Re: Cowl Lacing
Thanks for all the replies...it sure helped.
