26 Coupe Steering Column
dunoon
Topic author - Posts: 133
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Is there suppose to be any kind of rubber/cushion between the steering column and dash board?
Ruxstel24
- Last Name: Hanlon
Re: 26 Coupe Steering Column
I believe it should be a strip of leather.
- Last Name: Humble
Yes, molded rubber u shaped pad, one above and one below the steering column.
