Should I Seal A Brand New Fuel Tank?
Topic author - Posts: 296
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
I was lucky to find a new gas tank.
Before installing it, should I clean and/or seal it to prevent rust?
- Last Name: House
Re: Should I Seal A Brand New Fuel Tank?
No. I wouldn’t. Rust is your enemy. Will you pour anything but gasoline in your new tank? Will you leave gallons of gasoline in your new tank for many months after the touring season thereby asking for chunks of varnish to clog up the carburetor? We steam out, scourge with a variety of Ospho then seal old rusty tanks because new ones are inordinately expensive
- First Name: Bill
George;
No, gas only, and probably non-ethanol. No, I will drain gas out during non-driving time.
Question...Is rust less likely to form if the tank is full?
A new gas tank will last decades, best to drain tank for prolonged storage, just as you would for the carb.
Good inside storage in decent environment the tank insides will stay like new. If you are worried, drain and then spray bomb the inside with WD-40 and quickly replace the cap. Used to do that when living a couple of blocks from the Atlantic ocean. Ran thru lots of spray cans covering tools on the peg board and the kids beach bikes
If it’s a new tank and has normal use it will be just fine the way it is long after we’re all gone.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
no sealant BUT it would be wise to put a few gallons in it & slosh it around a bit to check for leaks before installing it. guess why.
Charlie
I think that is excellent advice.
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
I would not seal it. We have gone through several "best things since canned beer" products that eventually turned out to be the worst things since "sliced bread". I always use non-ethanol gas and make sure I have a full tank when I won't be using the car for several months. I have never had a rust/other matter problem in forty years. Just my .02.
