What Puller Do I Need?
Topic author - Posts: 304
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
What modern puller will work to remove this hub?
- First Name: Bill
Re: What Puller Do I Need?
I meant brake drum, not hub.
Bill, I'd be inclined to support the drum in a press and use the press to push the hub out. You will need a heavy tubular support for the drum. We keep a selection of starter/ generator housings for this purpose. Heat and rust penetrant may help.
Hope this helps.
Hope this helps.
- Last Name: Hanlon
You probably will need to pull the hub first.
Then push out the wheel studs and remove the drum.
This puller will work...
https://www.amazon.com/OTC-6574-Univers ... 0359662961
- First Name: Bill
Steve, I'd truly love to find one of those for sale, or rent!
Bill, I am posting this to spur your imagination...https://www.homedepot.com/p/URREA-Beari ... /202797899
If you have a pal with a lathe, you can turn up a split collar which will "grab" the hub and provide ample purchase area for a heavy puller to grab. Just be sure to remove the axle nut and turn it around and reinstall to keep from deforming axle threads.
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
I purchased this one from Harbor Freight for less than $10 and modified the ears and It worked great. The hub came off without out any heat.
If you can't pull It cold and have to heat It, pour a 5 gallon bucket of cold water on it after you get It red hot, be careful of the steam It will generate, It will shock the bond and it should come right off. And do as Scott said about the nut.
- First Name: Ted
- Last Name: Dumas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Your local auto supply May loan you one for free. Our O’Reillys does that.
With lugs like that I use a dog bone puller.
use one of the pullers shown above to remove the hub. Then press out the lugs and the drum should come right off. When you install the new drum or re-install the existing drum, press in NEW lugs.
Bill, take no notice of me!!!!! I read that you were looking to remove the hub from the drum. Even then, I got it wrong. The studs are pressed out first and then the drum comes off.
Sorry.
Sorry.
- First Name: Bill
Clarification...
What puller do I need to pull the entire hub and drum off the axle?
Any or all of the above shown will do the job - then the drum can be removed.
- First Name: Bill
Bill Crosby...
Do you remember the p/n of that puller at Harbor Freight?
- First Name: Bill
- Last Name: Crosby
Bill Everett, I just looked at the puller and there are no markings on It. I purchased It from HF many years ago just for this purpose because I could not find my old ford hub puller. It did a good job at a cheep price.
- First Name: Bill
Thank you, Bill.
- First Name: Bill
- Last Name: Dizer
- Board Member Since: 2014
The harbor freight puller has been a pitman arm puller, before being modified. It is normally used to pull the steering pitman arm off the tapered splined shaft of a modern steering box. It looks like the opening between the jaws has been widened to fit over the slot in the hub.
Yes, pitman arm puller. Most big auto parts chains have these heavier cast version.
China made but simple grinding of the lugs more wider to fit around the hub collar on wire wheel hubs lets them work.
Here’s mine:
Here’s mine:
- Last Name: Golden
Dan, I stopped by Harbor Freight today and bought one of those pullers.
The Part Number is 63684 and it cost $14.95 today without any coupons.
The opening is listed as 1 5/16 and needs to be 1 3/4 inch for the rear hub.
By careful calculations, and cutting both sides, I have exactly 1 3/4 inch now.
The frame is very hard and it required a Harbor Freight electric cut-off tool to make clean cuts.
The tool works fine, thanks for the tip!
- Last Name: Golden
Bill, that original Ford puller has a 5-Z-1172 number on it, but it is hard to see.
- Last Name: Wetherbee
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan
GEE-WIZ JIM, how did you know that so quickly? (Personal joke, please ignore me)
There is no such thing as a “free” lunch...
