Help ID aluminum high compression head
Alex Dragone
First Name: Alex
Last Name: Dragone
Post by Alex Dragone » Tue Jul 16, 2019 12:05 pm
I picked up this head recently with a bunch of parts, can anyone identify what this is? Who made it? The chambers look like a Z head. I may sell this in the classifieds. It’s brand new, never used. Any help is appreciated. Thanks!
MTFCA Number: 14972
MTFCI Number: 15411
Re: Help ID aluminum high compression head
Post by RajoRacer » Tue Jul 16, 2019 1:28 pm
"R" could be for a Rader head - is it a low or high - if low, I'd be interested.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Tue Jul 16, 2019 1:39 pm
It is not one of R. G's heads. It is a z head.
Herm.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jul 16, 2019 3:58 pm
How ya doin' Herm ? I believe the "Z" heads had the Z up there, didn't they ?
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Tue Jul 16, 2019 5:04 pm
I have a Z head on my car. There is a Z by the water outlet, not an R.
1926 Tudor
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Tue Jul 16, 2019 5:26 pm
I see some crude casting lines that my z head doesn't have plus the bolt holes look counted
Bored and lastly z I say it ain't a z head. Philip
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jul 16, 2019 5:38 pm
Is it a high or low head, Alex ? Let's see a photo from the front, please.
Alex Dragone
First Name: Alex
Last Name: Dragone
Post by Alex Dragone » Tue Jul 16, 2019 7:16 pm
It’s a high head. I can post more pictures tomorrow. It came from an old collector and I think this was purchased some time ago. It’s a nicely made head.
Post by Allan » Tue Jul 16, 2019 7:19 pm
My low Reeder head had the same redundant oblong hole between cylinders 2 and 3. It also had 'Reeder' cast inside the water outlet.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jul 16, 2019 7:23 pm
Thanks for the reply, Alex !
Joss
First Name: Joss
Last Name: Sanderson
Post by Joss » Tue Jul 16, 2019 10:13 pm
I have an older Z head with no Z id. Agree Reeder heads all said Reeder.
Post by Mark Gregush » Wed Jul 17, 2019 9:23 am
I am thinking someone cut up and used a stock head as a pattern. The chambers were built up and modified to what they wanted and used to make the mold. The lines running across it may be were it was cut apart. If you have a spare block you might do a trial fit first. The maker may not have taken into account for shrinkage. (One would hope they did if they got this far) You might also check how much water it holds compared to stock head. Block off the water outlet and flip over setting them level and fill both. See if it has about the same capacity as stock.
1920 Dodge touring
MWalker
Last Name: Walker
MTFCA Number: 314
Post by MWalker » Wed Jul 17, 2019 10:51 am
The Reeder heads have a "4" on the water outlet, and they don't have the "Z head/Haibe" shape to the combustion chamber. Their combustion chambers are shaped like the Ford ones, only shallower. And yes, they said "Reeder" inside the water outlet. I don't know what this "R" head is.
Dave S
First Name: David
Last Name: Simmering
MTFCA Number: 11531
MTFCI Number: 10138
Post by Dave S » Wed Jul 17, 2019 12:53 pm
The head is identical to the one that was on our Coupelet that is now in the Piquette Museum. It was driven many miles with excellent results. It is a Jensen head, made by Rod Jensen in Chicopee Falls, Mass. It was advertised in the Vintage Ford magazine in the 60's.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Jul 17, 2019 2:00 pm
I have a Jensen head on my 24 touring.
I have to look at the casting marks, but my head does not have the "groove" cut into the combustion chamber, it's straight across. The Z head combustion chamber looks more like the OP's, and should be 6:1.
Kevin Prus told me, the head on my car is THE head he used to make his mold for the 8:1 Prus head.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Jul 17, 2019 2:04 pm
This was before I cleaned it, you can see the combustion chamber is not the same.
Sorry, not a great picture.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Wed Jul 17, 2019 10:17 pm
R. G's heads are flat on the inside, are all the same depth, from one end to the other. They will " PING ".
The Z head is built like the Waukesha, and Hebbie High Power.
Herm.
Alex Dragone
First Name: Alex
Last Name: Dragone
Post by Alex Dragone » Tue Aug 20, 2019 11:49 am
Guys, I found out by looking on the box that this came in that this head was made by Rod Jensen of Massachusetts in the late 1970s. I have been told that the combustion chambers are basically identical to the modern Z heads that are offered today. This head is a low style head and has the Ford script. The modern Z heads offered are only high style and have no Ford script, so this is a pretty nice head. I just posted it in the classifieds if anyone is interested. Thanks for all the help.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Tue Aug 20, 2019 1:39 pm
I agree with the combustion chamber looks like a Z head...
Funny, my Jensen head looks identical on the top, but the chamber does not have the V shaped notch. (See pics above). Supposed to be 8:1....
Piewagon
Last Name: Regan
MTFCA Number: 14725
MTFCI Number: 77
Post by Piewagon » Wed Aug 21, 2019 2:13 am
Has anyone posted the amount of compression (measured in lbs) that the Z head produces or the amount of compression that the Prus head produces.? Just wondering.
