Magneto voltage tester
Tlitwin
Last Name: Litwin
* REQUIRED* Type and Year of Model Ts owned: 1926 touring
Post by Tlitwin » Tue Aug 27, 2019 2:44 pm
I believe what I have in the photo is a tool for testing magneto voltage. But no matter which way I connect it the gauge goes down below zero. I was putting one end on the magneto output and grounding the other end. Car does run well on magneto. I was curious as to how much voltage it is putting out as we just got done rebuilding the whole engine and transmission.[image]
[/image]
Les Schubert
First Name: Les
Last Name: Schubert
Re: Magneto voltage tester
Post by Les Schubert » Tue Aug 27, 2019 2:53 pm
The T magneto puts out AC power
I believe that you have a tester for old “B” radio batteries that produced 45 volts DC.
Tlitwin
Last Name: Litwin
Post by Tlitwin » Tue Aug 27, 2019 2:57 pm
Thanks Les, I just put new batteries in my analog voltage meter will try it when I get home later.
Post by Scott_Conger » Tue Aug 27, 2019 3:08 pm
Tom
when you get a reading from your voltmeter that you don't believe, don't worry, as a standard meter is not configured to give a meaningful reading. Do a search on "MTFCA magneto test" and use a lightbulb, or borrow an original or repro St. Louis Magneto Tester. This device is one of the very best items I have ever discovered during my "picking" days.
Last Name: Hjortnaes
Post by DHort » Tue Aug 27, 2019 5:40 pm
You can also test it with the ECCT if you have the additional software.
MKossor
Last Name: Kossor
Post by MKossor » Mon Sep 09, 2019 1:38 pm
Actually, the standalone ECCT can test the magneto output is sufficient to properly operate coils without the software. The test scale is similar to the venerable St. Louis Magneto tester for those familiar with that instrument. The scale is somewhat meaningless; based on model year as opposed to voltage output but still serves the purpose.
The ECCT with PC Software provides a lot more information; Magneto RMS output voltage under load, no load, magneto internal resistance, Magneto magnetic field strength and engine RPM.
Novice
First Name: Jim
Last Name: Davis
DC VoltMeter.
Post by Novice » Mon Sep 09, 2019 2:25 pm
I have a meter just like it and it is a DC meter. It may well have been used to test old tube type portable radio batteries. voltage range is about right but many had a 90 volt "B" battery along with 45 volt and others. You can test the meter with a 9 volt battery or on Your car. Wire lead on top is negative. point on meter case is positive.If You hood it up to a magneto. The meter needle may jerk a bit depending on engine rpm but wont give a reading.
