Started at 1:30 a.m. and met Dean Yoder at his place about 9:00. Dean did what he does best, quickly rebuilt the roller and the yoke that holds it for our K roadster. In a couple of hours, it was better than new, and off we went. Arrived at the Pink Pallace in Dearborn a few minutes ago.
Now, a week at Benson, and OCF. It doesn’t get much better........
The roller was worn down unevenly, and the brass holder grooved on the bottom:
Dean turned down a new roller, and tinned then babbitted the uneven surface. Now it’s as good as new, or better.
This is the third Model K Dean has brought back to life, and fifth K motor he has worked with.
The “K whisperer” and I have arrived........ in Dearborn
Bud Delong
- First Name: Kenneth
- Last Name: DeLong
Re: The “K whisperer” and I have arrived........ in Dearborn
Rob,Will the racer also be there? Bud.
- First Name: Henry
- Last Name: Lee
Sure is a Beautiful Car and entrusted by one of the BEST! Super Job Dean!
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
Rob
Topic author - Posts: 1553
- First Name: Rob
- Last Name: Heyen
Thanks Hank. Yes, Dean's the best.
Bud, unfortunately the racer motor needs attention and won't be out again until next spring. Will we see you this weekend?
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Are you sure Dean knows what he's doing ?
Bud Delong
- Last Name: DeLong
Rob,I think those days are gone but ? Bud.
Rob
- First Name: Rob
- Last Name: Heyen
Bud, take care. Off to the library this morning. Who would have ever thought my idea of the perfect day would be time spent at a research library. Certainly not my former teachers...........
