1926 Ignition Switch Screws
xtr2turbo
First Name: David
Last Name: Birch
Post by xtr2turbo » Sun Sep 01, 2019 5:03 pm
Hello
Does anyone know the thread size for the screws that hold the wiring loom to the back of the ignition switch?
Thank you
David
Re: 1926 Ignition Switch Screws
Post by DanTreace » Sun Sep 01, 2019 7:15 pm
Those short machine screws are 32 TPI, .....rather sure dia. is #8
xtr2turbo
First Name: David
Last Name: Birch
Post by xtr2turbo » Sun Sep 08, 2019 5:14 am
Thank you
I have ordered some
David
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Sun Sep 08, 2019 9:38 pm
The proper screw to use for the ignition switch is #6-32. The original screws have 5/16 inch of threads on #6-32 round head screws with small split lock washers. If the screws are too long they will prevent the springy contacts from going into the depressions in the fiber back plate inside the switch. If you have a crimping tool for electrical terminals like the one shown, you can easily trim the screws to the right length without damaging the threads.
1922 Coupe , 1926 Touring
xtr2turbo
First Name: David
Last Name: Birch
Post by xtr2turbo » Wed Sep 11, 2019 7:55 am
Thanks. I can confirm that no8 are too large. Received this morning. I'll order some no6
It's hard here as not a standard thread most places stick sobyou can't just go and try
Regards
David
xtr2turbo
First Name: David
Last Name: Birch
Post by xtr2turbo » Sun Sep 22, 2019 4:22 am
No6 x5/16 fits. Actually feels quite slack in the thread but tightens up ok.
Thanks for the suggestions
David
