What is this hood?
AdminJeff
Topic author - Posts: 1113
- Last Name: Stevenson
What is this hood?
Anyone?
It's a LOT different from this hood
. This is like a game of Clue.... I really need a visitor or two to come to Santa Rosa and help me identify half this stuff....
Jeff
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
Re: What is this hood?
Jeff, the first(rusty) one appears to be a '26-'27 hood. The second one(primered) one appears to be a repro hood for a '24-'25 high radiator. Dave
1925 mostly original coupe.
David S is right on!
I think David is correct, however, the side panels are on backward. The louvers should be facing out.
dobro1956
- First Name: Donnie
- Last Name: Brown
I agree with the others. top is 26-27 and the bottom is repro 24-25. I would love to come and play "Clue" with you. but the commute would be a little rough ..
Just keep posting the stuff here, we will all help figure it out .....
- First Name: Dallas
- Last Name: Landers
I think Langs has measurements on their hoods in the catalog. Can be confusing if sides are on wrong side.
Had to look twice but the lovers are indeed on backwards on the 24-25 high hood. The panels are in great shape. In the 24-25 hood pic it looks like the panel in the right corner of the pic is a low hood panel. Maybe!
AdminJeff
This is great. Right down to the backwards side panels! It was a puzzle. There are just dozens of pieces everywhere and Im piecing them all together best I can. I did match the bottom one to my '21, so that wasn't too bad. This guy loved rust colored primer. Better than rust by itself I suppose!
Jeff
AdminJeff
John kuehn wrote: ↑Mon Sep 09, 2019 9:39 pmHad to look twice but the lovers are indeed on backwards on the 24-25 high hood. The panels are in great shape. In the 24-25 hood pic it looks like the panel in the right corner of the pic is a low hood panel. Maybe!
Good eye. That's yet another set entirely. That's the one I matched to my '21.
Jeff
Maybe a repo also but not sure.
Hood dimensions
D Stroud
- Last Name: Stroud
Fellers, look again at the '24-'25 hood. The panels aren't on backwards, your looking at the shadows. The dimples for the hood hooks bear this out.
Dave
D Stroud
- Last Name: Stroud
Yep, never mind. I was thinking about them being on inside out, backwards didn't register. Yeah, I looked again.
Dave
Don D
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
Jeff,
Just a suggestion to help us help you would be to include a yard stick/tape measure next to an item so we have a scale as a size reference.
Best of luck with your quest,
Dom
Dom
