.10 over pistons Question
lorenzo26
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
Do they make .10 over pistons for a model t engine ?
Kerry
- Last Name: van Ekeren
Re: .10 over pistons Question
No, if you still have a std bore I doubt a .010" re-bore would clean it up, I've even had to take std's up to .060" at times to get a good finish.
Erik Barrett
- First Name: Erik
- Last Name: Barrett
Get a set of .030 pistons and have a competent machine shop bore and hone it. These blocks can go .060” and beyond. If you are worried about the longevity of a block that is .010” oversized at 90 years old you must be expecting to live to be 400.
- Last Name: Humble
Lorenzo, as you know the usual vendors only go up to .08, but if I remember some prevoius discussions, there may be more size options if you contact the manufacturers directly. Egge is one.
lorenzo26
- Last Name: leon
i will call them thank u all for input Lorenzo
