Another what is it?
70shovelhead
First Name: Preston
Last Name: Wells
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
Board Member Since: 2008
Another what is it?
Post by 70shovelhead » Fri Sep 13, 2019 12:59 pm
Fella had this laying on the table at an antique engine show I am at this weekend. Anyone want to guess what it is.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
Last Name: Juhl
Re: Another what is it?
Post by Oldav8tor » Fri Sep 13, 2019 1:01 pm
Spring separator - lets you lube between leaf springs.
70shovelhead
First Name: Preston
Last Name: Wells
Post by 70shovelhead » Fri Sep 13, 2019 1:25 pm
The gentleman is asking $50 for it. A little high I believe. He says Ford made one with script. Is that a fair price?
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Post by Allan » Fri Sep 13, 2019 8:14 pm
The handle section is supposed to screw off the blade. It is filled with grease, and when screwed back onto the handle, the grease is forced through the shaft and out the little slot in the blade, thus lubricating the spring at the same time. I have one just like it, with the brand cast into the handle. It is not a Ford part. It could well have preceded automotive work.
Last Name: Seth
Post by perry kete » Fri Sep 13, 2019 8:25 pm
I think $50 is high priced but then again I drive Model T's ! :lol: :lol: :lol:
Post by RajoRacer » Fri Sep 13, 2019 10:15 pm
I've got nearly every Ford Z tool and that was not one of them.
Post by Scott_Conger » Fri Sep 13, 2019 10:38 pm
Allan is correct in it's use, and it was called a Tomahawk spring lubricator. I have one and it works far better in theory than in practice.
http://www.mtfca.com/discus/messages/118802/122431.html
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Sep 14, 2019 1:37 pm
I really think Scott needs to buy this since he is deep into real cowboy country. When dim dar Ingins coming a runnin, there ain’t going to be no razor burns when he gets scalped. Just pull it out and say, “use this one”!
Hank
Post by Scott_Conger » Sat Sep 14, 2019 5:37 pm
Hank, yep, and if it's just a near-miss, they can leave a bit of grease for that period sporty look! :lol:
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Sep 14, 2019 6:36 pm
Yep! Just Going Get fuzz from me!!
