I do not know where to get high nuts since I moved to Florida but a high nut is about half again as tall as a regular nut and is much harder.they come in diameters from 5/16 on up. Easy to weld a cap to and still have room for an open end wrench. You can screw them down further on a threaded area and have less chance of bending that item if you thread it down to just above touching. If not tall enough put a bolt through it and weld 2 nuts together.
Fastenal may have them but I, m not sure.
making thread protecter knockers
Topic author - Posts: 260
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
- First Name: Rich
- Last Name: Bingham
Re: making thread protecter knockers
They're called "coupling nuts". A quick search shows that Lowes, Home Despot and Fastenall carry them.
"Get a horse !"
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Sounds like a grade 9 nut, yes, available at fastenal.
