Welding on a body
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Welding on a body
Post by Dennis_Brown » Sun Sep 15, 2019 9:05 pm
I need to do some patch work on my pickup and have body for a speedster that cracks. Does anyone use a flux core wire welder for this type of thing? Also is there any type of rod that can be used with a lower temp than acetylene?
I know gas wire feed is best but more than I want to spend at this time.
Ruxstel24
Last Name: Hanlon
Re: Welding on a body
Post by Ruxstel24 » Sun Sep 15, 2019 9:14 pm
I have used flux core wire feed welding...it's a little more sloppy than gas shield but it works.
Brass will work, but you need oxy/acetylene for enough heat.
Another possibility is panel adhesives.
https://www.3m.com/3M/en_JM/collision-r ... l-bonding/
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Sep 15, 2019 10:39 pm
This topic ranks high on the controversial topic list along with what type of motor oil and leaded/un-leaded gas discussions. This should prove to be a popular thread...
Of course the “best” welding methods happen to be the most expensive, but are also the most controllable, and have the fewest side effects. But any welding method can be used if done with proper caution and preparation.
No matter what welding method you use, ensure that your weld joints are as tight as possible, and clean! The tight joint will prevent undue shrinkage as the weld cools, as the surrounding material will support the hot area during rapid cooling. It’s a bit tricky to adjust a MIG (gas shield or flux core) welder to get full penetration without a joint gap, but it’s worth the effort to do so. Propper cleaning of the material will help ensure quality welds, in turn preventing welds from cracking during hammering (stretches weld filler material to offset shrinkage and restore intended panel shape).
With good technique, it is possible to butt weld flat panels together with minimal overall panel distortion. Lapping panels is an easy way to prevent weld burn thru... but at the cost of uncontrollable shrinkage, and a horrible scar on the inside of the panel. Some may not care in the moment, but a good looking repair on the inside is typically the measure of a “quality” repair after the filler and paint are applied.
Lead and brass used to be common practice in body repair, but have fallen from grace not only because of the obvious, but the residual flux can cause filler/paint adhesion issues and also aggressively corrode the sheet metal if not cleaned properly.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Mon Sep 16, 2019 10:05 pm
I like to use a mig welder for my body work. Stack tack welds around the panel to avoid distortion. Grind and fill. Take your time. I get it that you don't want to spend the money right now, but a decent mig welder will pay for itself in the years to come. I have been down the gas welder route for welding or brazing, they have their place; go get a mig welder for body work.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Sep 17, 2019 10:01 am
I'm surprised no one has mentioned "hammer welding" as a technique for patching or fabricating sheet metal forms. A good hand with oxy-acetylene can weld accurately butted pieces without using hardly any filler rod, and the result requires only minimal finishing. Parts are tacked in place then "stitched" to complete the seam, the "hammering" part meaning edges are brought back into alignment with a hammer and dolly block as needed as the work progresses.
"Back in the day" :roll: many manufacturers did extensive gas welding in this manner to make complex forms on fenders and bodies as some shapes could not be stamped on dies even if production numbers could justify the expense of tooling. Most independent auto makers' cars were thus pretty much "hand made" up to WW II.
(Mind you, I ain't sayin' I can do it, but it's mighty impressive to see it done ! :D )
"Get a horse !"
Post by Scott_Conger » Tue Sep 17, 2019 10:08 am
like this?:
Post by Scott_Conger » Tue Sep 17, 2019 10:09 am
and ending something like this? :D
Post by Scott_Conger » Tue Sep 17, 2019 10:11 am
What I learned from all that is: Buy A Better Car To Start With
Reese-G
First Name: Reese
Last Name: Ghij
Post by Reese-G » Tue Sep 17, 2019 10:15 am
@Kevin Pharis you forgot water pumps!
Hammer welding works good but sometimes the section will get bigger during the process.
Post by Scott_Conger » Tue Sep 17, 2019 2:54 pm
I've never experienced expansion when hammer welding, except to create it to un-do shrinkage. If it did in fact expand, there are a couple methods to shrink metal without a whole lot of trouble.
This panel had a bulge in it like someone threw a bowling ball into the trunk...bulge is gone and panel is straight with no filler:
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Sep 17, 2019 3:02 pm
Scott, EXACTLY like that !! :P Good on ya for truly "restoring" that body.
"Get a horse !"
Post by Scott_Conger » Tue Sep 17, 2019 3:12 pm
Thank you Rich
Just goes to show what a person can do if they have enough time and nothing better to do (also helps to be crazy)
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Sep 17, 2019 8:08 pm
Scott if you had better metal to work with then you would have to find something else to do for therapy!
LOL
Hank
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Tue Sep 17, 2019 8:49 pm
Somebody on another forum had mentioned using old Chevrolet truck doors for patch panels. They work well for the bottom of the body because they have a brake line in them already but not quite 90*, and the metal is slightly curved already. I know this isn’t a T body but it’s similar. The back doors were attached so I used those skins to make one door skin, the other side was better.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Sep 17, 2019 9:52 pm
See Scott, Corey has real therapy!!!
Post by Scott_Conger » Tue Sep 17, 2019 10:17 pm
Hank, yer killin' me!
tdumas
First Name: Ted
Last Name: Dumas
* REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Post by tdumas » Tue Sep 17, 2019 10:46 pm
I used a flux core welder with reverse polarity. I used a copper back up strip riveted to hold the patch panel to the original sheet metal. Once done, I removed the copper strip and welded up the rivet holes. It took some grinding and a second pass to get a solid weld.
