Installing seat upholstery
Mark Osterman
Topic author - Posts: 1014
- Last Name: Osterman
Has anyone made a comprehensive video for upholstering the replacement seat springs available through Langs/Snyders ? I just received a new seat and back rest. The only video I can find for reupholstering a seat is from a demonstration event and seems to be shot from off to the side. Is there an actual video tutorial? Also .. for the seat back?
- Last Name: Strange
Re: Installing seat upholstery
As far as the backrest and seat springs go the upholstrey kit I bought from Classtique had instructions on how to build a spring compressor and installing the covers. The rest of the installation instructions had a lot of tips to use. There was enough information without the now available video. The video will surely be a help. Nothing better than show and tell!
Mark Osterman
Yes, that link takes you to the same bad video with all the action taking place off to the right and too far away. I can’t see how the material is being connected to the bottom of the metal seat frame or any other detail. It is nice to see how the seat compressor works.
Try calling Classtique and ask them directly, or maybe they will be at Hershey and you can talk to them there?
Mark Osterman
Great idea. Would like to talk to them at Hershey. Thanks!
They use to come to Chickasha and do demonstrations on how to install the seat spring covers. I saw them there a few times and they delivered my interior kit for my 21 Touring. Don’t know if they still do it or not. But once you see how it’s done it’s surprising how easy it is. Just take your time and it’s all good.
Mark if your going to Hershey you can the get information you need from Classtique. But if you don’t make it I still have the instruction sheets I got with my Classtique kit for my 21
Touring. It helped me when I installed the upholstry. Let me know if you need it and I”lol send it to you.
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
Mark are you refering to the video of Mike from Classtique doing the seat bottom? I found that Video very helpful and watched it several times to do my seat bottoms. The camera showed how he crimped the material to the spring pretty clearly. You must be talking about another video
1924 Touring car
There's No Substitute for Proper Lubrication
Mark Osterman
Yes, probably. The video was shot from behind a couple rows of seats. It would have been better to shoot a video up close at another time .. as an instructional video. The details are covered in the audio but not easy to see from a distance.
- Last Name: Hjortnaes
Mark
Sent you a PM
Sent you a PM
I taught Elizabeth how to make a spring compressor many years ago. As far as the backrest spring: You want it as low as possible, without interfering with the bottom cushion. Also use plenty to padding up and over the tackstrip. If you look at a lot of restored cars, often you will see the outline of the top of the backrest cushion. That is because the backrest spring is too high. You can make two fabric hangers for that spring, and adjust them until you get the spring in the proper place. Most of this stuff is common sense. The secret is to take your time.
Mark Osterman
I received the new seat bottom and back springs from Lang’s yesterday. They are made by Snyder’s. I’ll pick up the seat kit from Classtique when I’m at Hershey on the Thursday of the show. The new seat spring set is framed with aluminum. I’m assuming that the original frame is steel. Is there any compromise in strength by using aluminum in the new set? I’m 230-ish pounds and hope it holds without distortion. Was thinking about transferring the new coil springs to the old frame, but maybe I’m worried about nothing. Mike at Classtique did ask if I wanted to use hog clips or channel for installation. Which is better? Also, I can see through the holes in my old upholstery that there seem to be some type of sheet metal band inside the sides between the upholstery and the body. Is this a spacer to keep the upholstery from resting against the sheet metal? I haven’t seen any mention of these in older posts.
I would use 3/4" plywood for the compressor. It takes a lot of pressure to compress those springs. For the bottom I used two one by fours. I don't know why, but Langs and Snyders both sell Mac's upholstery kits. I would stay away from them. Mike at Classtique does a much better job. I sewed a piece of plastic welt around the skirt of the seat spring upholstery to hold it in place after the channel is compressed. I used wide jaw vise grips for the channel.
Mark
All the covers for the later T's used with me have had the beading in the edge that fits into the channel as Larry mentioned, use a channel lock pliers to fold over and close the channel, stock Ford method.
The channel makes for a very neat appearance and more practical as the spring base sits best in the seat frame with stock method.
Hog rings are modern and weren't used on the Ford, but can be used. In this case I preserved the new spring cushion by using hog rings, as the cover was only a blanket, for simple job. Easy to remove the hog rings and then this new spring base could be done later with correct channel install of the right cover.
The compressor is needed to do this work on seat springs, this one is non-Ford, but operation is the same, layout the cover, place spring over, the compress the spring, and fasten the upholstery covering.
Mark Osterman
Thanks so much! Those pictures are just what I need. I did speak to Mike at Classtique yesterday about the installation and picking up my seat kit at Hershey. Also spoke with him about how helpful it would be for them to create installation videos shot professionally without an audience so there is a free view to see both the whole scene and close ups as needed.
Quickm007
- First Name: Mario
- Last Name: Brossard
Thank you sharing these tips!
Really appreciated.
Really appreciated.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
When I did mine, the plywood compressor I used was about four inches all the way around bigger than the seat spring. I used two 2X4's for the bottom somewhat close to the edges of the spring to distribute the force more evenly.
