Cracked Clutch Plates
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Thu Oct 03, 2019 7:51 pm
I've taken apart alot of transmissions, but I dont remember ever finding this many cracked discs. Can't imagine the heat it took to do this.
First Name: Henry
Last Name: Lee
Re: Cracked Clutch Plates
Post by Henry K. Lee » Thu Oct 03, 2019 8:28 pm
WOW! Never seen that! Maybe my Dad back in his youth drag racing? LOL
Hank
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Oct 03, 2019 8:51 pm
Improper adjustment and/or a weak spring, would be my hypothesis. ;)
Post by RajoRacer » Fri Oct 04, 2019 11:33 am
How torn up is the clutch drum ????
Post by Scott_Conger » Fri Oct 04, 2019 12:11 pm
And THAT, Steve, is the $64,000 question, isn't it?
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Oct 04, 2019 12:59 pm
Worn thin, or just cracked ? Running low on oil ?
Post by Steve Jelf » Fri Oct 04, 2019 2:20 pm
I've seen lots of them, but not like that.
got10carz
Last Name: Meixner
Post by got10carz » Fri Oct 04, 2019 3:43 pm
The drum has groves worn, but I've seen worse. Improper adjustment, bad driving skills, and a oil pan with a plug in the top hole all could be factors.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Sat Oct 05, 2019 8:23 am
My initial thought on those plates is they are “flexing” in operation going from flat to dished. The cracking appears to be
adjacent to the cut out on the outer plates. As suggested by others a possibility is catching on the drum and not sliding
I’m aware of some rebuilders who intentionally bend one or two plates into a dished form to give a quicker cleaner
disengage into neutral. Alan
