How to get seating of starter field/pole pieces
Autie
First Name: Keith
Last Name: Keller
* REQUIRED* Type and Year of Model Ts owned: 1
Post by Autie » Fri Oct 18, 2019 6:57 pm
When rebuilding a starter W/O having a pole piece spreader available (as in the service book fig.466) to seat the starter field/pole pieces, any suggestions?
Re: How to get seating of starter field/pole pieces
Post by Mark Gregush » Fri Oct 18, 2019 8:32 pm
Make 2 hard wood wedges (like door stops) so they would stick out both side of the case, round over the flat side somewhat match the curve in the shoe. After you get the pole shoe screws in as tight as you can, drive them in to expand the shoes. While you can only do 2 shoes at a time, it would work. We used a setup like that for a while till we got the tool. Don't try and make the slope too steep.
Post by John kuehn » Fri Oct 18, 2019 10:06 pm
I saw a guy doing this on the forum years ago and it works pretty good. Install the starter fields in the case and tighten them up snugly with a large screwdriver that fits the screws. Mount a piece of pipe in a vise horozontality. I can’t remember exactly what size but I’m thinking it’s 1 1/2” but not sure but use one that’s close to the ID of the fields.
Simply mount the case on the pipe and use a rubber or wooden mallet to firmly seat the fields as you tighten the field screws. I’ve used this method on my starters and it works fine. Pretty simple using items around the shop.
AZTerry
First Name: Terry
Last Name: Loftus
* REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Post by AZTerry » Fri Oct 18, 2019 11:32 pm
I use an inexpensive exhaust tail pipe expander
Last Name: Hatch
Post by Dan Hatch » Sat Oct 19, 2019 8:42 am
Second the exhaust pipe expander. Just replace the bolt. Dan
Autie
First Name: Keith
Last Name: Keller
Post by Autie » Sat Oct 19, 2019 2:50 pm
Thank you, gentlemen
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Sun Oct 20, 2019 12:16 am
I use two C clamps, one at each end of the pole pieces so there is room to get to the new screw. Cheap and effective.
Tony Bowker
La Mesa, California
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sun Oct 20, 2019 11:03 am
An expandable mandrel works.
