Cleaning up is a good thing
Post by Steve Jelf » Sat Oct 26, 2019 2:05 am
One of the benefits of cleaning up and organizing the shop is finding stuff you forgot you had.
I don't remember where I got this, of course, but all it needs is an adapter to fit a Model T engine.
Re: Cleaning up is a good thing
Post by Wayne Sheldon » Sat Oct 26, 2019 3:44 am
Looks like Christmas came early!
Make sure that hose is in good condition, and up to the task of about 80 psi and you should be good to go! Once you get that adapter.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sat Oct 26, 2019 4:01 am
I've got one just about like that Steve, I don't know where it is right now either! :lol: Dave
1925 mostly original coupe.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Post by Tom Hicks » Sat Oct 26, 2019 7:30 am
Cleaning up is necessary, but I am not good at it. I tend to start a little project, have to stop for lack of materials or whatever, then go on to another project without putting the tools back because I will need them when I come back to the first project. So too many projects with tools and materials strewn around. When I can't find a 1/2" or 9/16" open end wrench I stop all projects and put all tools away. I have eight 1/2" wrenches and six 9/16" wrenches.
At least I have gotten to the point where I have a place for every tool and know where it goes, that simplifies putting them away.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Oct 26, 2019 7:43 am
When I was a kid, dad had one like that he carried in every car he ever owned. Standard equipment as was a tool box .
JunkyJud
First Name: Justin
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 1924 TT C cab
Post by JunkyJud » Sat Oct 26, 2019 8:21 am
I've often wondered if the gasoline vapor that is pumped into the tube with one of these does any kind of damage over time.
Justin in Western PA
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Sat Oct 26, 2019 9:04 am
There is no gasoline vapor pumped in, fresh air comes in thru the part that screws in to the head.
Post by John kuehn » Sat Oct 26, 2019 9:33 am
We had a spark plug pump we used to pump up tires on the farm. I think it came with 3 adapters. TSC and Western Auto sold them. Do they still make them? If the plug was easy to get to it was easy to use. But when they were popular flat head engines were common so it was easy to hook one up. Not so much anymore!
Post by Steve Jelf » Sat Oct 26, 2019 9:40 am
Yes and no. They're available with a shorter hose for use on motorcycles, but they're not made for cars. Something to do with catalytic converters.
Post by Mark Gregush » Sat Oct 26, 2019 12:11 pm
I have one too but it is missing all the adapters.
Post by Steve Jelf » Sat Oct 26, 2019 4:16 pm
If it has 14mm spark plug thread, you only need this adapter.
JunkyJud
First Name: Justin
Last Name: H
Post by JunkyJud » Sat Oct 26, 2019 4:44 pm
Ahh, that's clever. Do they work well?
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Sat Oct 26, 2019 5:03 pm
Not sure I buy the catalytic converter part. Most newer cars have spark plugs that you can’t get to and coils mounted direct to the plug. Also most people today would be incapable of hooking one up. Probably not enough demand.
Post by Steve Jelf » Sun Oct 27, 2019 12:53 am
Dad used one in the Plymouth for blowing up air mattresses. I'm the guy in the striped shirt. 1946.
tmodeldriver
Last Name: Hester
* REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Post by tmodeldriver » Sun Oct 27, 2019 8:35 am
When using one of these adapters be sure to short out the spark plug wire while it is disconnected. Running the engine with the wire just dangling could damage the coil.
Also, I don't think the T engine is going to pump the 55 psi needed for 30x3 or 30x3 1/2 tires.
Post by Original Smith » Sun Oct 27, 2019 11:17 am
I wonder if Schrader made those for Ford? I've seen them with Ford script. You could make an adapter out of an old spark plug.
Post by Mark Gregush » Sun Oct 27, 2019 11:29 am
Well I moved mine so now I can't find it! :lol: After looking on Ebay, knowing the size of the threads on Steve's might not help anyway. I see now there were several different types with different thread arrangements.
Post by Scott_Conger » Sun Oct 27, 2019 12:04 pm
Bob
Jim Eubanks reply that it draws fresh air in is a clue as to how it develops pressure: the pump is a sort of accumulator pump with a smaller volume cylinder being swept by the larger volume of the piston. It's pump per sweep is much smaller than the piston, but is multiplied in pressure (compressed) for the tire fill.
Most accumulator pumps are hydraulic/air, but with different swept volumes, air/air will work too. This guy's video shows a Schrader pump and you'll see the volume of the actual pump itself: https://www.youtube.com/watch?v=2LjbjtPR8BQ
Post by Mark Gregush » Sun Oct 27, 2019 1:54 pm
I found mine, right where I put it after I moved it! ;) Mine is like the sample below, without adapters fits 18mm spark plug hole. Poop! I can find adapters to fit 14mm plugs into 18mm hole, not so much the other way. :x You can buy them but the thread is wrong.
https://www.ebay.com/itm/Vintage-Sears- ... Sw5ltdh6dv
But should be an easy make if I can get to the lathe. Got more then I need of the 14mm to 1/2 pipe ones.
dlmyers
First Name: Dale
Last Name: Myers
Post by dlmyers » Sun Oct 27, 2019 2:36 pm
Here's mine.
The word "Tractor" is below the Ford script.
I have no idea why the first photo posted twice. Or why the gauge photo is below the text.
The old forums are a gold mine of information.
tmodeldriver
Last Name: Hester
Post by tmodeldriver » Sun Oct 27, 2019 3:13 pm
Howdy, Scott. Thanks for the explanation and video. That's exactly how a steam powered water pump can push make-up water into the same boiler it's getting the steam from. I shoulda have knowed. :oops: Regards, Bob.
Post by John kuehn » Sun Oct 27, 2019 3:39 pm
The Ford (tractor) pump is really neat! I bet that Ford pump was made in the 8-9n Ford era which was 39- 52. Could be later but not much later. The braided cloth covered hose goes way back anyway.
The fluctuating needle brings backs memories when airing up a large back tire on the back of the Ford tractor we had. It took a while and after it got aired up the plug adapter was really hot! We blew out the one we had after speeding up the engine because I thought it was to slow. Got another one from Western Auto to use when we had to.
Ken Lefeber
First Name: Ken
Last Name: Lefeber
Post by Ken Lefeber » Mon Oct 28, 2019 12:44 am
I saw this on the running board of an American car at the Hershey car show.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Oct 28, 2019 9:33 pm
Steve, was it beside the speedometer you were looking for? :)
Post by Steve Jelf » Mon Oct 28, 2019 10:45 pm
I wish. That's still on the missing list. :(
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Oct 29, 2019 9:45 am
Cleaning up just seems to make room for more stuff.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Tue Oct 29, 2019 10:01 am
Cleaning up is good. I do it about once a month and while I'm building a car, I go through my mis parts bins to remind me what I've already ordered for that car and what I need.
I'm not going to admit to how many times I've ordered the same part multiple times because I didn't remember that I already had it. :oops:
1924 Touring
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Tue Oct 29, 2019 10:34 pm
Go buy a 1/2 by 1/8 pipe bushing, drill it out to the proper diameter for a 14 mm tap, tap it and you have your adapter. Make 4 and use them for your spark plugs. I prefer steel pipe bushings.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Oct 29, 2019 11:18 pm
I sometimes order parts months before starting a project to spread out the costs. I keep spreadsheets for both of my cars where I list parts or services purchased with "from" and expenditures columns. It helps me keep track of what I have and what I need.
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Post by Philip Lawrence » Tue Oct 29, 2019 11:43 pm
I have been cleaning and organizing my shop and in the process so far have found enough pieces and parts to build up two more model T's.
Post by Allan » Wed Oct 30, 2019 4:17 am
Mark, if I spent the time getting as organised as you, I wouldn't get anything done. The only spreadsheet I have is used to throw over stuff on which I don't want paint overspray. As for expendidtures, if I kept a record of those and my wife found out, well............... I much rather keep the peace than keep the records.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Oct 30, 2019 8:51 am
That is some serious organization Mark.
I work with spreadsheets at work and since my garage is a happy space, spreadsheets are a no-go 😀
I just keep all my extras for spares down the road,
1924 Touring
