Safety wire
Topic author - Posts: 381
- First Name: Don
- Last Name: Ellis
Safety wire
What is the most common size used on a model T?
- Last Name: Humble
Re: Safety wire
.032 and .051. I use the smaller wire for smaller applications and the larger wire for wishbone ball joint, flywheel bolts, differential bolts, and other larger bolts.
Aircraft safety wire pliers will make a professional twist for a nice clean job.
Many older posts regarding the best way to do safety wire.
Re: Safety wire
I ran out awhile back, and I had to go to three different auto parts stores to find it!
- First Name: Don
- Last Name: Ellis
Re: Safety wire
I tried that, they have no idea what I’m talking about. Amazon has it though.
- Last Name: Humble
Re: Safety wire
I get mine at Aircraft Spruce.
Re: Safety wire
I also procure my S.S. wire through the local aircraft parts store - iron "bailing wire" I p/u at Wilco Farm Store or Tractor Supply.
- Last Name: Stroud
- Board Member Since: 2011
Re: Safety wire
Harbor Freight has Stainless Steel safety wire very reasonable, not sure about the sizes though. Dave
1925 mostly original coupe.
- First Name: Randall
- Last Name: Strickland
Re: Safety wire
if you want plain old tie wire you can get it at most concrete places it is used to tie rebar.
Re: Safety wire
Ace hardware has safety wire in different sizes.
- First Name: Tony
- Last Name: Bowker
Re: Safety wire
I use 0.032” wire from McMasters
Tony Bowker
La Mesa, California
La Mesa, California
