I got it running again two weeks ago using a Model A manifold with a bolt on adapter to use a 1.25" SU carburettor that I had used on my Indian Stroker, with a borrowed new Texas T distributor it fired up with the second turn of the crank and I had a celebratory drive around the farm paddock! Its still very much a work in progress to get it roadworthy but I hope to have it on the road in the spring
I have also been gathering the parts to build a TwinT, with inspiration from the late Gary LeFever's maroon car. I spoke to Gary about it 10 years ago in a phone conversation after I had seen pictures of it here on the forum. I now have two fresh built 1926 engines and the parts to build a 1926 rolling chassis. I hope to link the two engines on a one piece folded oil pan (with separate oil baths) and will join the two cranks with a duplex chain joint as Gary did.
I look forward to getting involved with the forum from the other side of the pond
Cheers
Steve
[image]https://www.facebook.com/photo.php?fbid ... =3&theater[/image]
