Source for Hard-to-Find Fasteners
Redleg
Last Name: Neal
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster Pickup
Post by Redleg » Wed Nov 06, 2019 8:19 pm
Hi folks,
I’ve found a great source for hard-to-find bolts and screws, both in steel or brass. Best of all, no minimum quantities when ordering. Quality is better than that sold at the big box stores. Plus, they ship fast, too.
http://www.Boltdepot.com
I am not associated with them in any way, just a happy customer.
John
John Neal
Virginia
‘25 Roadster Pickup
Jugster
First Name: Bob
Last Name: Coiro
Board Member Since: 2009
Re: Source for Hard-to-Find Fasteners
Post by Jugster » Thu Nov 07, 2019 5:29 pm
Excellent! Thank you.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Fri Nov 08, 2019 6:30 am
You got my hopes up but I guess I'll just have to keep looking
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 08, 2019 7:49 am
Been using them for many years, very satisfied.
Hank
Banjoe
First Name: Joe
Last Name: Lucas
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Banjoe » Fri Nov 08, 2019 8:09 am
What a great resource. Even have elevator bolts that I need right now.
Many thanks for this link, John
“We don’t do these things because they are simple, we do them because we thought that they were simple”.
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Fri Nov 08, 2019 2:00 pm
Awesome!
How are their wood screws? Do they have cut threads like vintage ones?
Tractordoc
Last Name: Barclay
* REQUIRED* Type and Year of Model Ts owned: 1920 coupe
Post by Tractordoc » Sun Nov 10, 2019 5:18 pm
When John first posted this it reminded me that I needed some straight slot screws, so I ordered a bag of 100. I think the quality looks good but I don't know how the threads are made. They look like they are cut to me, tried to get a picture maybe you can tell from the picture. George
Post by Scott_Conger » Sun Nov 10, 2019 7:38 pm
Post by Allan » Sun Nov 10, 2019 11:22 pm
George, what you show is a self tapping screw used in metalwork. Wood screws will have a tapered thread for its length and there will be some plain shank. Once installed, the appearance will be the same.
Post by Scott_Conger » Sun Nov 10, 2019 11:45 pm
I started out to disagree with you, but conclude that you are correct. In George's defense, though, the screw he posted is very commonly sold as a wood screw in the US.
Post by Original Smith » Wed Nov 13, 2019 8:57 am
I've had good luck with Blacksmith Bolt in Portland, Oregon.
Post by Allan » Thu Nov 14, 2019 2:03 am
Scott, in the interests of accuracy, I found a box of such screws in the stuff I just loaded for the Bendigo swap meet. They are labeled as chipboard screws!
My theory is that tapered wood screws would tend to work out of chipboard, but parallel threaded screwd would maintain their hold.
While chipboard is made of wood derivatives, the screws are still self tapping.
Learned something else today
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Thu Nov 14, 2019 7:01 am
What I would like is a nice slotted fillister head that has a portion not threaded in an 8-32, 10-32, and 12-32 but that is impossible to find
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Thu Nov 14, 2019 10:38 am
Chad, I can help you with the #8s. How many do you want?
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Thu Nov 14, 2019 11:51 am
. . . They are labeled as chipboard screws!
My theory is that tapered wood screws would tend to work out of chipboard, but parallel threaded screws would maintain their hold . . .
The wood screw we have known for decades is tapered, and depending on the application (wood species, etc. ) they operate as a wedge, often failing because they split wood. "Sheet metal" screws being parallel threaded have proven (for me) to be more reliable in situations where a project sees a lot of weather. That's neither here nor there when we want fasteners that are "period correct" in their look. Personally, I have a phobia for Philips-head fasteners, and even "regular" machine bolts and nuts look very different nowadays from the old stuff. Heads were heftier, nuts more generous. They're just overall more pleasing to handle and work with.
"Get a horse !"
Post by Scott_Conger » Thu Nov 14, 2019 11:56 am
you're probably aware, but will tell you anyway: there are drill bit/countersinks that drill the correct hole for wood screws and the wood doesn't split. I have some and use them for any project requiring a wood screw...they're tapered drills...pretty clever.
Here's an example of them: https://www.mscdirect.com/browse/tnpla/ ... n0EALw_wcB
Post by Steve Jelf » Thu Nov 14, 2019 2:51 pm
What I would like is a nice slotted fillister head that has a portion not threaded in an 8-32, 10-32, and 12-32...
Why with a portion not threaded? Where are they used?
Post by Scott_Conger » Thu Nov 14, 2019 6:33 pm
Chad
http://www.accuratescrew.com/catalog/fillister-head
Steve
they are used when you want a captured fastener
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Thu Nov 14, 2019 6:37 pm
I find them used all over. My particular purpose requires that the un threaded portion be the diameter of the threaded portion so what was posted will not work.
