What are these ??
Michael Davis
Topic author - Posts: 297
- First Name: Michael
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1923 Center door
What are these ??
Found theses with a bunch of Model T parts I purchased. No Clue! what they are ????
Mike
Mike
got10carz
- Last Name: Meixner
Re: What are these ??
Accessory shocks.
Michael Davis
- Last Name: Davis
Thanks. They must go between the leaf spring and the shackle ?
Mike
Mike
The two with the short bolts appear to be the rears and bolt in place of the rear axle spring perch. The two without bolts (bolts are missing, but should be fairly standard) should be about a quarter inch narrower than the rears. They bolt through the spring perch holes (In the axle!) with a long heavy-duty bolt that also holds the wishbone underneath the axle.
I cannot be certain without a size scale, but that is what they look like. I have seen a few pictures of these on cars over the years. And some years back, someone posted a couple ads for them on our forum.
They look neat, but I don't think I would want to try using them. I suspect they may have a similar "stability" issue as another common early type shock absorber made for model Ts. The "suspended from a spring in a can" shocks have resulted in a few fatal model T accidents. These would make great wall-hangers mounted between empty rear housings and front axle axle and springs. The rears might be okay to use on modern roads. However the fronts at modern road speeds likely could oscillate and result in loss of control or even front axle collapse.
These I think are fairly rare. I have only seen a handful of them in nearly fifty years of playing with model Ts (probably seen thousands of front and rear ends at swap meets?). They really should be preserved, and seen. Just not used.
As I go to post, I see you added a comment/question. These go between the shackle and the axle, replacing the perch. Not between the leaf spring and shackle.
Michael Davis
- Last Name: Davis
Wayne Thanks for the information. Very interesting. I can not imagine any advantage by using them,
Thanks Again
Mike.
PS
I will be offering them for sale soon.
Thanks Again
Mike.
PS
TMiller6
- First Name: Thomas
- Last Name: Miller
I own a NOS set of these as well. The guy who sold them to me some 40 years ago called them Grey Ghosts. My front pair is slightly different in that the “U” extends further horizontally.
The way they are supposed to work is by providing a different natural frequency of the two Ford springs. The two frequencies will tend to dampen the ride. I never used mine because leaf springs by their rubbing provide some damping without a shock absorber.
Tom Miller
One of my customers has a set on the rear of his roadster. Guess they work ok.
I don't know anything about these but they look like they are for the rear. The pictures, from an MTFCA thread, of the front axle shows double set
Michael Davis
- Last Name: Davis
Well again Thanks for the pictures and info. So many inventions and different approaches
Mike
Mike
Jay posted this a while back:
http://www.mtfca.com/discus/messages/118802/142950.html
