What are these wood rails
Jeff Hood
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Post by Jeff Hood » Fri Nov 15, 2019 3:39 pm
These wood rails and corners were in a bunch of stuff I aquired. It was a mix of parts from Model T, Model A, and ?? Does anybody recognize them?
Jeff Hood
Last Name: Hood
Re: What are these wood rails
Post by Jeff Hood » Fri Nov 15, 2019 3:42 pm
Some more pics
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Fri Nov 15, 2019 3:52 pm
I think the first picture appears to be the door striker support on touring and or roadsters. Some scale would help😊
Tony Bowker
La Mesa, California
Post by John kuehn » Fri Nov 15, 2019 6:19 pm
The frame rails (if that’s what they are) look like they could be for a Roadster of some kind.If you have a T measure the distance between the front and center body to frame rail mounts ,center to center. If you have some holes that measure the same distance on your wood maybe that’s what it’s for?? Just a guess.
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Fri Nov 15, 2019 10:00 pm
Model A's that had wood sub rails were; 1930 / 31, A - 400, Victoria, & 2 door sport phaeton.
Looks like you have parts for one of those body styles !
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Sat Nov 16, 2019 2:20 am
Well, actually, many A bodies had wood side rails: Fordor Sedans, Cabriolets, Convertible Sedans, Vickys. These are not from the Fordors, nor the cabriolets, I would suspect Vicky or Convertible Sedan.
T'ake care,
David Dewey
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Post by kmatt » Sat Nov 16, 2019 5:24 pm
They look like they may fit a Model A Vicky by the curve in the back, I don't know about a delux convertable 2dr Sd, so few of those were made.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Sat Nov 16, 2019 7:05 pm
The top picture looks like my 31 Victoria frame rails and rear seat armrests. Art
Post by John kuehn » Sat Nov 16, 2019 7:38 pm
Curious but who makes Model A wood. Is it avaliable for most A’s? I have Model T’s along with most on the T forum and getting a wood kit for T’s isn’t always easy and for some T’s getting harder to find a supplier that’s easy to get a hold of. Most of the time!
Post by Mark Gregush » Sat Nov 16, 2019 8:27 pm
many dealers carry wood kits like;
https://www.mikes-afordable.com/category/1123D.html
The kits might be made by;
http://www.classicwoodproductsllc.com/
