Or, recommend a good "store bought" one. I've had an old one for years that , as it turns out, is obviously not for a Model T.
diy valve spring compressor?
thom
Topic author - Posts: 329
- First Name: Tommy
- Last Name: Coffey
Anybody got a homemade valve spring compressor that works well on Ts? 'Specially one that will work on an engine with the manifolds still on. Let' see it, please.
Re: diy valve spring compressor?
I bought this fancy one for $2 at a yard sale.
Here's one I cobbled together from scraps on hand.
Bill Robinson
- First Name: Bill
- Last Name: Robinson
The big factor-
A vaporizer would really test a man's patience! OUCHcan you do it with the manifolds still on?
thom
- First Name: Tommy
- Last Name: Coffey
I looked again and found "my other" valve spring compressor that will work on a T, then went to the local flea market and bought a Sunnen brand one that works even better, for $3.00.
Bill
you must be a very patient man!
for me, ANY manifold in place taxes my patience!
the reality is, to me at least, not only does it require less use of a scarce resource (patience!), is that the speed gained by removing the manifolds well exceeds the time spent replacing them, so for me it isn't even a question of "IF" I take them off...those suckers are coming off!!
John Warren
- Last Name: Warren
I’m with Scott on the manifolds and I like Steve’s first spring compressor
thom
- First Name: Tommy
- Last Name: Coffey
The other seven valves came and I removed a few more of the old ones. I find that some valves have as little as .006 clearance with the adjustable lifters "run all the way down". Not knowing how much adjustment is available in the lifters but knowing that the valves will "sink" some as they seat in, I need to have some taken off of the stems at the machine shop. But how much?
John.Zibell
- Last Name: Zibell
I would remove only about 0.010 inch. You can always remove more later if needed. You should easily adjust for 0.010 to 0.012 inch clearance with the adjustable lifters.thom wrote: ↑Sat Nov 16, 2019 9:07 pmThe other seven valves came and I removed a few more of the old ones. I find that some valves have as little as .006 clearance with the adjustable lifters "run all the way down". Not knowing how much adjustment is available in the lifters but knowing that the valves will "sink" some as they seat in, I need to have some taken off of the stems at the machine shop. But how much?![]()
1926 Tudor
thom
- First Name: Tommy
- Last Name: Coffey
Problem is- remove more later means remove valves, replace gaskets, and another trip to the machine shop.
