Putting a 14 back together, putting in the long bolt on the steering bracket (through the wood block), am I correct that there is no washer involved?
Ben
Steering Bracket Hardware
Ben Umberger
Topic author - Posts: 35
- First Name: Ben
- Last Name: Umberger
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 20 Touring, 16 Depot Hack, 17 Roadster 27 Touring
Duey_C
- First Name: Duane
- Last Name: Cooley
Re: Steering Bracket Hardware
The 25 Service Manual does not mention nor show a washer. Pages 35 & 36. But you did ask about a 14.
Hope this helps!
Hope this helps!
Ben, no need for a washer. The bolt head is p against the frame and the nut against the bracket.
Hope this helps,
Hope this helps,
