Model t rear axle: Cad or detailed drawings
Davey1916
First Name: Cameron
Last Name: Davey
* REQUIRED* Type and Year of Model Ts owned: 1916 torpedo speedster
Post by Davey1916 » Mon Dec 02, 2019 11:55 pm
Hey all, I'm after a cad file or someone that has sketched up a detailed drawing for the rear drive axles. The only thing I have close to either is the image i've attached which I found on here.
Many thanks for any help
Cam from DownUnder
Re: Model t rear axle: Cad or detailed drawings
Post by Steve Jelf » Tue Dec 03, 2019 12:10 am
Davey1916
First Name: Cameron
Last Name: Davey
Post by Davey1916 » Tue Dec 03, 2019 1:34 am
Thanks Steve unfortunately I'm after dimensions ect. But those drawings sure are cool!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Dec 04, 2019 1:45 am
That drawing you have is pretty basic, and obviously lacks much needed tolerances. An interesting method of defining the taper across the entire length of the axle too... IIRC, it’s 3/4” per foot with centerline taper, can’t help you with gauge diameter, but know you need to keep pretty tight tolerance on the taper to maintain overall axle length
Post by Original Smith » Wed Dec 04, 2019 1:22 pm
Just use the Ford Service book. You don't need drawings.
Post by TRDxB2 » Wed Dec 04, 2019 3:19 pm
Here is a link with an additional picture for cutting the key way
http://www.mtfca.com/discus/messages/50 ... 1231423423
