Vaprizer outlet gasket
FundyTides
Topic author - Posts: 226
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Does anyone know if the Vaporizer outlet tube gasket (Ford # 6270) is available anywhere or has anybody used anything else as a substitute? There is none on mine and it seems to work ok but thought maybe I should put one on. Maybe a proper size o-ring would work ok?
Re: Vaprizer outlet gasket
Honestly, if you have a vaporizor that is working "just fine", I would be inclined to leave it alone.
