modern connecting rods with insert bearings
James kitchener
First Name: james
Last Name: Kitchener
* REQUIRED* Type and Year of Model Ts owned: 1914 touring 1923 touring
Post by James kitchener » Sat Dec 14, 2019 7:27 pm
Has anyone used these new rods from snyders? langs has them as well, langs web site says you need pressuzed oil system but snyders does not. They have a built in diper so i dont see why you would need pressurizd oil. thought i would give these a try tired of old bent and twisted rods lol.
Kerry
Last Name: van Ekeren
Re: modern connecting rods with insert bearings
Post by Kerry » Sat Dec 14, 2019 8:45 pm
I have fitted some up for other club members, no feed back on how they are running as yet. First your crank needs to be spot on, no room for error or ajustment, also I believe some of the insert bearing shells are no longer available, need to check that out.
Post by Scott_Conger » Sat Dec 14, 2019 9:27 pm
James
with inserts, the babbit is very very thin. This makes them far less tolerant to debris in the gap. Original babbit bearings can digest a surprising amount of debris with little effect on the crank...not so much with modern shells. Along with pressurized bearings, they generally take a filter as well, thus reducing the suspended contaminants. I suspect that suppliers "requiring" this are acting in their own best interest to get the longest possible life out of their parts in their customers' cars. Knowing this, without an oil pump and filter, I personally do not see their use as an improvement in either performance or reliability.
Just recognize the limitations which come with the convenience, and for that matter, how do you quantify "convenience"?
To each his own. When you reach 10,000 miles, let us know how they held up.
James kitchener
First Name: james
Post by James kitchener » Sat Dec 14, 2019 10:32 pm
I believe these bearing inserts are of a thicker design with thrusts built into them,modern tin copper babit bearings would not last long in a non pressurized system but i am only guessing because there in not much info on them.
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Post by D.Yoder » Sat Dec 14, 2019 11:17 pm
They weigh more than stock lite Ford rods.??
Kerry
Post by Kerry » Sun Dec 15, 2019 1:10 am
Dean.
Chucked one on the scales and comes in at 20oz's with out the bearing fitted.
John Warren
Last Name: Warren
Post by John Warren » Sun Dec 15, 2019 11:00 am
A lot of Model A guys are going with inserts with no mods to the oil system. Hi mileage is at 60,000+ miles. My race car has all insert bearings, only about 2,000 miles on it now. It is a must to keep clean oil in it!. Model A's have an oil pump, but not a pressured system. It floods the lifter area that has oil passages to the mains and the rest flows to the front of the engine to the dipper tray.
D.Yoder
First Name: DEAN
Last Name: YODER
Post by D.Yoder » Sun Dec 15, 2019 7:42 pm
You got me . I always weigh rods in Grams.
Had to get the scales out. The stock Ford rods I weighed were 14—15 oz.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Dec 15, 2019 8:14 pm
You have to remember A's do not have band material floating around getting in to bearings, if you can filter the oil before it gets there great ideal then, I know years ago it does not take much to spin out an insert bearing.
James kitchener
First Name: james
Post by James kitchener » Tue Dec 31, 2019 1:56 am
Still waiting to hear from someone who has tried these rods , apparently they have sold out of the standard bearings so someone must be trying them :?:
