my 1921 Pick-ups gearbox have "collapsed" by most likely use of incorrect material for the triple gear bushings, so that it have had severe wear resulting in broken teeth and then total failure when the broken teeth ended up in the mesh.
I have obtained another good set of drums and triplegears that have worked together, and now I am controling the pins in the flywheel. They do not appear weared at all and no ovality can be meassured and since the sit firmly in the flywheel, I seriously consider to reuse them.
But they seem to be some sort of oversize. They measure 17,40 mm which is a little under 11/16" (17,46 mm). However looking on Langs catalog it seems the standard size is 0,677", which is close to 17,20 mm. I know a little of the cars past, and it may very well be back to the early 1970's that this engine and gearbox was last overhauled. Back then we did not have the same fast and easy access to spare parts from the US and both the triple gear bushings and the pins may have been made by a local machine shop.
The "new" triplegear I have has what appears to be correct "original" bushings but with a too little bore. My plan was to try to find a 11/16 reamer but I think the 0,06 mm (0,002") gap is far to insufficient. Or is it? I'm not interested in seized bushings.
Please advice
